SSL Phone and ASA Configuration
I have the attached configuration, built form all the exmaples I have found.
If I Anyconnect it all works and I can access the network.
However when I load the Cert to the Phone, I am constatntly getting VPN Auth failed.
Is there something I have missed, also every time you change CUCM does the Cert get reload to the Phone ?
Isn't this meant to be easy !!
  • IP Telephony
1 REPLY
An update to this, I have done some debugging and found that the ASA Cert that I export to CUCM are the same :
that is the Crt Hash from the export from the ASA is the same as the Phone 64bit Hash.
But when I connect to the phone to the outside of the ASA, the Cert hash being precented to the Phone does not match the Phone 64 hash or the ASA hash !!
So the question is why ??
179
