Stange Call Park Issue
Hi Guys,
I'm running Call manager 6.1.3.3190-1 and I'm having a stange cal lpark issue.
When I make an outgoing call from a phone, I can park it no problem.  However when I receive an incoming call, I am unable to park it, the phone says no call park no available,
I'm not sure if the gateway needs access to the call park partition but I added it anyway and still no joy.
Any ideas??
Neil
Re: Stange Call Park Issue
just an update guys, even though my gateway is in a device pool set to register with the SUB first, once I created the Call Park extn on the PUB it appeared to work.  So i'm guessing for whatever reason my gateway is registering with the PUB and not the SUB??  Anyway, I have call park extensions on both now so it should be fine.
Neil
You should always create a call park range in every server a phone might register in order to avoid this, since call park ranges only work for devices registered to the same server if all your devices failover to a server with no call park range, they won't be able to use it.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
159
