Static IP Address on IP Phone?
One of our users needs to make sure that the IP address of his Cisco 7965 phone never changes.  Is it possible to configure a phone with a static IP address?  If so, how?  Thanks!
1 REPLY
Re: Static IP Address on IP Phone?
Yes, go to to the phone.
Press settings, press **# to unlock settings and disable DHCP. Then configure IP address, default GW and TFTP server.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
163
