Static on PRI calls
Problem: Some phone users both Cisco & Turrets are experiencing static when they are having conversation. Again this static is totally sporadic,
We have tried changing turrets but no luck, and IPC says that it is the phone system.
Following is the time-line as the events occurred.
December-14: Checked to slip secs on both T-1 and E-1 and noticed some on T-1 interface, and fixed slip secs by adjusting clock source. After the changes there were no slip seconds and thought this would fix the issue
December-20: This time took help from TAC, and they suggested and which we did to Upgrade IOS 12.4(5) which has new DSP code 4.4.20 and upgrade the PVDM2.
December-26: We are still having same issue, and it this point we asked Verizon
January-2: Verizon said that their circuit is clean with no problems, coincidentally users said he did not hear any static after the test. So we thought that Verizon testing kind of fixed that static, but not
January-9: We are having static again
1 REPLY
Bronze
Re: Static on PRI calls
You have to Upgrade IOS latest versions. This may be because of frame slips on the PRI caused by a clocking mismatch.
488
