Status IP Address
Hi all,
We have added new phones into call manager manually , some are registered correctly , but some phones are showing Status : Unregistered  and showing IP address
KIndly let me know the troubleshooting steps plz
Thanks in advance
Karthik
1 ACCEPTED SOLUTION
Status IP Address
Hi Karthik.
This status indicates that an IP Phone was registered to CUCM and than has lost its connectivity and doesn't reache the CUCM anymore.
Try to check connections and routing  between IP Phones showing that status and CUCM
Carlo
Please rate all helpful posts "The more you help the more you learn"
Status IP Address
Hi Karthik.
Carlo
Status IP Address
Hi Cario,
Thanks for your response
Karthik
431
