stcapp uc520 uc500 and mac address
Hello everybody,
I would like to use the 4 FXS port of my UC500 as normale ephone using stcapp.
Where can I find the mac address to configure into the ephone statement relevant to the FXS port?
Thank you very much
Johnny
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: stcapp uc520 uc500 and mac address
Similarly to your ATA case, enable auto registration and observe which mac are actually presented. The next available ephone tag will be used, you the place the correct mac under it.
You move the Chassis MAC over three digits, and then add the voice-port number. 0/0/1 becomes 001, etc.
Here's a guide on it:
http://www.cisco.com/en/US/docs/routers/access/vg202_vg204/software/vg2_vg4_voip_ps2250_TSD_Products_Configuration_Guide_Chapter.html#wp1059863
hth,
nick
From my UC520:
nicmatth-sip(config)#do sh diag | I Chassis MAC
Chassis MAC Address : 001d.45b9.6980
hth,
nick
I need 4 mac address, one for each voice port in order to set it into any ephone
I think there should be a way to know them.
otherwise how can I configure my ephone referred to the voice ports?
hth,
nick
606
