08-23-2013 01:41 PM - edited 03-16-2019 07:01 PM
Here is the scenario. On CME I have a pots dial-peer for LD calls 901[1-9]..[1-9]....... and also voip dial-peers for some LD destinations for TEHO, say 901442.......
When a call is made to a 442 destination, say 9014425555555 it looks like the call is routed once over the pots dial-peer and once over the voip dial-peer.
How do I block 901442....... calls on pots dial-peer so that it is always gets routed through the voip dial-peer? Of course all other 901.......... calls are to be routed through the pots dial-peer.
I tried some transaltion rules with the reject statement (quite possible I did not apply them in the correct way) but it did not work.
Waiting for any suggestions.
Thanks in advance,
08-23-2013 01:52 PM
Try
huntstop
08-23-2013 02:43 PM
I thought of that. Where do I apply it? To the pots or voip dial-peer? Sometimes the call routes through the pots dial-peer first but it always should do through the voip dial-peer.
08-23-2013 06:13 PM
Make sure the the voip dial-peer appears before the pots dial-peer and apply the huntstop to the voip dial-peer.
