Strange 7911 Auth Fail problem
I've got a 7911 that just isn't playing ball.
It starts it's firmware update (It's stuck trying a firmware update) and downloads jar11 & cnu11 fine.
However, when it comes to apps11, it pauses for a long time just saying "Upgrading", then it *very* briefly flashes up "Auth Fail" then restarts the firmware upgrade process. If you watch a wireshark, it downloads apps11 fine from the TFTP server. In fact, it even starts to download dsp11 from the TFTP server !
Now I'm sure you're all going to say: "Use firmware 8.5.2" Sorry, tried that, still no joy.
This is happening with 8.5.2 & 9.2.1 and both SIP & SCCP images.
Before I admit default, and consign the phone to the bin, any last suggestions ?
GTG
Please rate all helpful posts.
Green
May be try factory reset
Step 1 Unplug the power cable from the phone and then plug it back in.
The phone begins its power up cycle.
Step 2 While the phone is powering up, and before the Applications Menu button flashes on and off, press and hold #.
Continue to hold # until the message LED on the handset flashes on and off in sequence in red.
Step 3 Release # and press 123456789*0#.
You can press a key twice in a row, but if you press the keys out of sequence, the factory reset will not take place.
After you press these keys, the message LED on the handset flashes faster in red and the phone goes through the factory reset process.
Do not power down the phone until it completes the factory reset process and the main screen appears.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_administration_guide_chapter09186a00805adaec.html#wp1085546
Alex
Regards, Alex. Please rate useful posts.
Green
Just another bit of info
From the 9.2.1 firmware release notes
Firmware Upgrade Issues for SCCP
Note For all SCCP firmware upgrades from firmware release versions earlier than 8.3(3) to version 9.2(1) or greater, you must first upgrade your firmware to an intermediate version (8.3(3) - 8.5(2)) then upgrade to 9.2(1).
as acampbell words,, you need internediate fw to solve your issue
be patient with this point to amuze your IP Phone
As I said in my initial post: "This is happening with 8.5.2 & 9.2.1 and both SIP & SCCP images."
As I said in my initial post "It's stuck trying a firmware update"
Green
What firmware version is on the phone prior to the
firmware upgrade.
Alex
I don't know. The phone is stuck trying to update it's firmware. If I could stop it doing that, it would be less of a brick....
GTG
Hall of Fame Super Gold
Try older firmware.
Paolo Bevilacqua wrote:
Try older firmware.
I've tried:
- 8.3.3
- 8.3.2
- 8.3.2SR1
- 8.3.2SR4
- 8.2.1
None of them work. (The closest to working was 8.3.3)
I think I'm going to have to admit defeat and consign the phone to the CallManager in the sky...
GTG
Green
GTG,
What if you boot the phone so that it onmly has access to the DHCP server (NOT THE TFTP)
Can you then press the setting keys and see what the existing firmware version is.
Alex
Once a phone has decided to start the firmware update process, I've never been able to persuade it to stop.
(I was once told there's a key sequence you can use to stop it - but it's never worked for me)
Just to be sure, I restricted the phone to only see a DHCP server, and it's just sitting there on the firmware upgrade screen saying "Upgrading"
GTG
Green
GTG
May be this bug refers to the issue
CSCsh62801 Bug Details
SIP7911 stuck during automated upgrade/downgrade
Symptom:
SIP7911 is stuck during automated upgrade/downgrade. This was seen consistently during 9th,5th,9th and 5th iteration of the script run.
Conditions:
Observed on SIP7911 during upgrade/downgrade from 8-3-0-25S to 8-3-0-26S.
Workaround:
None.
Further Problem Description:
None
StatusStatus
Fixed
(Verified)
Severity Severity
3 - moderate
Last Modified Last Modified
Any Time
Product Product
Cisco Unified IP Phone 7900 Series
Technology Technology
1st Found-In 1st Found-in
8.3(1)
Fixed-In Fixed-in
8.3(0.27)
3.3(5)ES66
3.3(5)SR2b
4.1(3)ES118.1
4.2(3)ES38
4.3(1)ES9.1
4.3(1)SR1a
4.1(3)SR5c
8.4(0.27)
8.4(0.43)
Component(s) Component
sw-phone-7911
Regression Regression
Y
Alex
As there's no work around, I guess the phone is just a brick now :-(
GTG
Green
GTG
I think the last option would be
8.0.3
cmterm-7911_7906-sip.8-0-3.cop
See if it take that then upgrade.
Probably through more jumps
If not I think we have exhausted this one
Cheers
Alex
2791
