Strange issue with incoming call from certain countrys
Hello guys!
I have a cluster with CUCM  8.0.3.20000-2 8.0 . in Spain .
The topology is very simple :
TELCO "Is an ACME server"  --sip------------------ 2800 router with  (C2800NM-ADVIPSERVICESK9-M), Version 12.4(24)T2------------------- CUCM -Cluster
The problem is regarding incoming calls from Uruguay,Brazil. When the call enter the 2800 and forward to CUCM the G.729 codec under the
Content-Type: application/sdp is no send .When the phone hook-off still ringing and the final error on CUBE is :
Received:
SIP/2.0 503 Service Unavailable
Via: SIP/2.0/UDP 172.26.254.30:5060;branch=z9hG4bK24613FCC
From: <sip:50765500505@172.26.254.30>;tag=7755AAB4-2325
To: <sip:915786322@172.26.254.41>;tag=2c6ead86-57b1-4553-8bec-f27e30084b15-35003492
Date: Mon, 23 Jan 2012 16:01:20 GMT
Call-ID: 26BE30D-451411E1-8C32A158-B79B2307@172.26.254.30
CSeq: 101 INVITE
Allow-Events: presence
Reason: Q.850;cause=47
Content-Length: 0
If we change the codec to G711 works well.
Bellow the configuration and a bad and good calls "traces"
Any ideas guys= :d
The configuration of 2800 is :
Current configuration : 12725 bytes
! Last configuration change at 11:14:34 CET Thu Dec 22 2011 by EKT
! NVRAM config last updated at 12:29:40 CET Thu Dec 22 2011 by EKT
version 12.4
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
hostname CUBE_BM_IBA
boot-start-marker
boot-end-marker
no ip bootp server
no ip domain lookup
--More--         ip domain name KUTXA.VITAL
no ipv6 cef
voice service voip
address-hiding
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
sip
  rel1xx disable
  min-se 90
  asserted-id pai
  g729 annexb-all
  sip-profiles 1
--More--         !
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711alaw
voice class codec 2
codec preference 1 g711alaw
codec preference 2 g729r8
voice class sip-profiles 1
request ANY sip-header Allow-Header modify ", UPDATE" ""
response ANY sip-header Allow-Header modify ", UPDATE" ""
--More--         !
voice iec syslog
voice source-group DE_TRUNK_FAX_SIP
access-list 21
translation-profile incoming DE_TRUNK_FAX_SIP
voice source-group DE_TRUNK_VOZ_SIP
access-list 11
translation-profile incoming DE_TRUNK_VOZ_SIP
voice translation-rule 11
rule 1 /^/ /8/
voice translation-rule 21
rule 1 /^/ /5/
voice translation-rule 111
rule 1 /^0/ //
voice translation-rule 112
rule 1 /^8/ //
--More--         !
voice translation-rule 113
rule 1 /9.*/ /943504458/
voice translation-rule 114
rule 1 /9.*/ /943504463/
voice translation-rule 115
rule 1 /^[23]....$/ /943504458/
voice translation-rule 116
rule 1 /^2....$/ /943504463/
voice translation-rule 121
rule 1 /^4/ //
voice translation-rule 122
rule 1 /^5/ //
voice translation-profile A_CUCM_FAX
translate called 122
--More--         voice translation-profile A_CUCM_VOZ
translate called 112
voice translation-profile A_TRUNK_FAX_SIP
translate called 121
voice translation-profile A_TRUNK_FAX_SIP_PRUEBAS
translate calling 114
translate redirect-called 116
voice translation-profile A_TRUNK_VOZ_SIP
translate called 111
translate redirect-called 115
voice translation-profile A_TRUNK_VOZ_SIP_PRUEBAS
translate calling 113
voice translation-profile DE_TRUNK_FAX_SIP
translate called 21
--More--         voice translation-profile DE_TRUNK_VOZ_SIP
translate called 11
voice-card 0
archive
log config
  logging enable
  logging size 800
  notify syslog contenttype plaintext
  hidekeys
path flash:archived-config-
maximum 14
--More--          write-memory
ip tftp source-interface Loopback1
ip ssh maxstartups 10
ip ssh time-out 30
ip ssh source-interface Loopback1
interface Loopback1
description IP DE GESTION
ip address 10.1.2.64 255.255.255.255
ip flow ingress
ip flow egress
interface FastEthernet0/0
description CONEXION LAN VOZ (CUCM y demas)
ip address 172.26.254.30 255.255.255.0
--More--          ip access-group 169 in
ip access-group 167 out
ip flow ingress
ip flow egress
duplex auto
speed auto
interface FastEthernet0/1
description SIP TRUNK HACIA EUSKALTEL
no ip address
duplex auto
speed auto
interface FastEthernet0/1.3998
description VPLS SIP TRUNK VOZ
encapsulation dot1Q 3998
ip address 172.31.252.4 255.255.255.240
interface FastEthernet0/1.3999
description VPLS SIP TRUNK FAX
encapsulation dot1Q 3999
ip address 172.31.251.4 255.255.255.240
ip access-group 166 in
--More--          ip access-group 168 out
no cdp enable
router ospf 3
log-adjacency-changes
no auto-cost
network 10.1.2.0 0.0.0.255 area 0
network 172.26.254.0 0.0.0.255 area 0
ip forward-protocol nd
ip route 10.1.2.65 255.255.255.255 172.31.252.5 254
ip route 172.26.182.101 255.255.255.255 172.26.254.253
no ip http server
no ip http secure-server
ip flow-export source Loopback1
ip flow-export destination 172.26.101.160 9996
ip radius source-interface Loopback1
logging 172.26.101.160
access-list 11 remark DE_TRUNK_VOZ
access-list 11 permit 172.31.252.1
--More--         access-list 21 remark DE_TRUNK_FAX
access-list 21 permit 172.31.251.1
access-list 166 permit ip any host 10.27.66.2
access-list 166 permit ip any any
access-list 167 permit ip any host 10.27.66.2
access-list 167 permit ip any any
access-list 168 permit ip host 10.27.66.2 any
access-list 168 permit ip any any
access-list 169 permit ip host 10.27.66.2 any
access-list 169 permit ip any any
no cdp run
snmp-server community cgrc1999 RW
snmp-server community public RO
snmp-server community ServKutxa RO 53
snmp-server community kut89208 RW 54
snmp-server host 172.26.99.14 ServKutxa
radius-server attribute 44 include-in-access-req
--More--         radius-server domain-stripping
radius-server vsa send authentication
control-plane
call fallback active
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp fax t38 ecm
sccp local FastEthernet0/0
sccp ccm 172.26.254.40 identifier 2 version 7.0
sccp ccm 172.26.254.41 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
--More--         !
dial-peer voice 1 voip
preference 1
service session
rtp payload-type nse 99
session protocol sipv2
incoming called-number 9T
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 2 voip
preference 1
service session
rtp payload-type nte 100
incoming called-number 0T
dtmf-relay rtp-nte
fax rate 14400
--More--          no vad
dial-peer voice 3 voip
preference 1
service session
voice-class codec 2
incoming called-number 4T
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 11 voip
description WAN-VOZ-ACME
translation-profile outgoing A_TRUNK_VOZ_SIP
preference 1
service session
destination-pattern 0T
voice-class codec 1
--More--          session target ipv4:172.31.252.1
session transport udp
dtmf-relay rtp-nte
no vad
dial-peer voice 21 voip
description WAN-FAX-ACME
translation-profile outgoing A_TRUNK_FAX_SIP
preference 1
service session
destination-pattern 4T
voice-class codec 2
session target ipv4:172.31.251.1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 101 voip
description VOZ_CUCM_PPAL
translation-profile outgoing A_CUCM_VOZ
--More--          preference 2
service session
destination-pattern 8T
voice-class codec 1
session target ipv4:172.26.254.41
dtmf-relay rtp-nte
no vad
dial-peer voice 102 voip
description VOZ_CUCM_BKP
preference 3
service session
voice-class codec 1
session target ipv4:172.26.254.40
dtmf-relay rtp-nte
no vad
--More--         dial-peer voice 121 voip
description FAX_CUCM_PPAL
translation-profile outgoing A_CUCM_FAX
preference 2
service session
destination-pattern 5T
session target ipv4:172.26.254.41:6060
dtmf-relay rtp-nte
trunk-group-label source DE_FAX
codec g711alaw
fax rate 14400
no vad
dial-peer voice 122 voip
description FAX_CUCM_BKP
preference 3
service session
voice-class codec 2
--More--          session protocol sipv2
session target ipv4:172.26.254.40:6060
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 12 voip
translation-profile outgoing A_TRUNK_VOZ_SIP_PRUEBAS
preference 1
service session
destination-pattern 0943008728
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 22 voip
--More--          description WAN-FAX-ACME
translation-profile outgoing A_TRUNK_FAX_SIP_PRUEBAS
preference 1
service session
destination-pattern 4945162118
voice-class codec 2
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 201 voip
description prueba_caso2433581
preference 2
service session
answer-address +582127450447
voice-class codec 1
--More--          session target ipv4:172.26.254.41
dtmf-relay rtp-nte
no vad
dial-peer voice 202 voip
preference 3
service session
voice-class codec 1
session transport tcp
dtmf-relay rtp-nte
no vad
sip-ua
g729-annexb override
The log of a bad call is :
Received:
INVITE sip:915786322@172.31.252.4:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.31.252.1:5060;branch=z9hG4bK6uqovh206o6h6n4ia6g0.1
From: <sip:50765500505@172.31.252.1:5060;user=phone>;tag=SDj7jb001-172.16.221.2651000+1+adae0002+7fa94043
To: <sip:915786322@172.31.252.4:5060;user=phone>
CSeq: 483705438 INVITE
Expires: 180
Min-SE: 90
Session-Expires: 1800
Supported: replaces, 100rel, timer
Content-Length: 291
Request-Disposition: fork, parallel
Allow: INVITE, BYE, REGISTER, ACK, OPTIONS, CANCEL, SUBSCRIBE, NOTIFY, PRACK, INFO, REFER, UPDATE
Call-ID: SDj7jb001-dcfdc333ba35543ea110591226d01dc1-c54qtk0
P-Asserted-Identity: <sip:50765500505@172.16.221.26;user=phone>
Privacy: none
Max-Forwards: 69
Contact: <sip:50765500505@172.31.252.1:5060;transport=udp>
v=0
o=- 3536323280 3536323280 IN IP4 172.31.252.1
s=-
c=IN IP4 172.31.252.1
t=0 0
m=audio 11226 RTP/AVP 8 18 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
a=maxptime:30
a=silenceSupp:on - - - -
SIP: (601844) Attribute mid, level 1 instance 1 not found.
an 23 17:13:24.015: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 23 Jan 2012 16:13:23 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
190037: .Jan 23 17:13:24.019: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:915786322@172.26.254.41:5060 SIP/2.0
Date: Mon, 23 Jan 2012 16:13:24 GMT
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  90
Cisco-Guid: 40384383-1158943201-2351735128-3080397575
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1327335204
Contact: <sip:50765500505@172.26.254.30:5060>
Expires: 180
Max-Forwards: 68
P-Asserted-Identity: <sip:50765500505@172.26.254.30>
Content-Disposition: session;handling=required
Content-Length: 249
v=0
o=CiscoSystemsSIP-GW-UserAgent 5422 413 IN IP4 172.26.254.30
s=SIP Call
c=IN IP4 172.26.254.30
t=0 0
m=audio 18598 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
190038: .Jan 23 17:13:24.023: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
190039: .Jan 23 17:13:24.027: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Contact: <sip:915786322@172.26.254.41:5060>
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "20948 PABLO LAPLANA" <sip:20948@172.26.254.41>
Content-Length: 0
SIP/2.0 180 Ringing
To: <sip:915786322@172.31.252.4:5060;user=phone>;tag=7755AAC8-CBD
Remote-Party-ID: <sip:915786322@172.31.252.4>;party=called;screen=no;privacy=off
Contact: <sip:915786322@172.31.252.4:5060>
Content-Length: 0
SIP/2.0 180 Ringing
CSeq: 101 INVITE
P-Asserted-Identity: "20781 PALOMA DIEZ" <sip:20781@172.26.254.41>
Content-Length: 0
190051: .Jan 23 17:13:29.007: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
ACK sip:915786322@172.26.254.41:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
190056: .Jan 23 17:13:29.027: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.26.254.30:5060;branch=z9hG4bK2461521BF
From: <sip:50765500505@172.26.254.30>;tag=7755BE44-BAB
Date: Mon, 23 Jan 2012 16:13:29 GMT
Call-ID: 5680BDD-451411E1-8C34A158-B79B2307@172.26.254.30
Min-SE:  90
CSeq: 101 INVITE
Timestamp: 1327335209
Expires: 180
Max-Forwards: 68
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 8308 4413 IN IP4 172.26.254.30
s=SIP Call
t=0 0
m=audio 17756 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
190057: .Jan 23 17:13:29.031: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Mon, 23 Jan 2012 16:01:25 GMT
CSeq: 101 INVITE
Content-Length: 0
190058: .Jan 23 17:13:29.035: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:915786322@172.26.254.41>;tag=2c6ead86-57b1-4553-8bec-f27e30084b15-35003502
CSeq: 101 INVITE
Content-Length: 0
Sent:
SIP/2.0 180 Ringing
Content-Length: 0
190078: .Jan 23 17:13:44.239: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
The log from a call that process well :
eceived:
INVITE sip:943008712@172.31.255.4:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.31.255.1:5060;branch=z9hG4bK6s906530ao0hmmgbp210.1
From: <sip:50765500505@172.31.255.1:5060;user=phone>;tag=SDl7m5f01-172.16.221.2651001+1+8fd00003+69d9dfcc
To: <sip:943008712@172.31.255.4:5060;user=phone>
CSeq: 20038592 INVITE
Expires: 180
Min-SE: 90
Content-Length: 291
Call-ID: SDl7m5f01-13b7f302d8f21d7905bab1dd543bf962-c54qtk0
Privacy: none
Max-Forwards: 69
Contact: <sip:50765500505@172.31.255.1:5060;transport=udp>
v=0
o=- 3536319816 3536319816 IN IP4 172.31.255.1
s=-
c=IN IP4 172.31.255.1
t=0 0
m=audio 10638 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=ptime:20
a=maxptime:30
SIP/2.0 100 Trying
Date: Mon, 23 Jan 2012 15:16:47 GMT
Content-Length: 0
.Jan 23 16:16:47.965: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:943008712@172.26.253.41:5060 SIP/2.0
Via: SIP/2.0/UDP 172.26.253.30:5060;branch=z9hG4bK23C54210FE
From: <sip:50765500505@172.26.253.30>;tag=EE04CC4C-1F39
To: <sip:943008712@172.26.253.41>
Call-ID: 1A3859B3-450C11E1-8F7099E3-58230DFA@172.26.253.30
Min-SE:  90
Cisco-Guid: 0439820490-1158418913-2406128099-1478692346
CSeq: 101 INVITE
Timestamp: 1327331807
Contact: <sip:50765500505@172.26.253.30:5060>
Expires: 180
Max-Forwards: 68
P-Asserted-Identity: <sip:50765500505@172.26.253.30>
Content-Length: 282
v=0
o=CiscoSystemsSIP-GW-UserAgent 8083 0 IN IP4 172.26.253.30
s=SIP Call
c=IN IP4 172.26.253.30
t=0 0
m=audio 18180 RTP/AVP 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
.Jan 23 16:16:47.969: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Mon, 23 Jan 2012 15:03:36 GMT
CSeq: 101 INVITE
Content-Length: 0
.Jan 23 16:16:47.977: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:943008712@172.26.253.41>;tag=8c9c6e7c-528c-4fbf-a0b6-7aaf5f9921e5-41414082
CSeq: 101 INVITE
Contact: <sip:943008712@172.26.253.41:5060>
P-Asserted-Identity: "6000032 OC VITORIA" <sip:6000032@172.26.253.41>
Content-Length: 0
SIP/2.0 180 Ringing
To: <sip:943008712@172.31.255.4:5060;user=phone>;tag=EE04CC58-0
Remote-Party-ID: <sip:943008712@172.31.255.4>;party=called;screen=no;privacy=off
Contact: <sip:943008712@172.31.255.4:5060>
Content-Length: 0
.Jan 23 16:16:52.921: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Session-Expires:  1800;refresher=uas
Require:  timer
Content-Length: 237
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 172.26.253.41
s=SIP Call
c=IN IP4 172.26.253.47
t=0 0
m=audio 18756 RTP/AVP 18 101
a=ptime:20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
Hall of Fame Super Gold
You should always use G.711. Thats gives the best call quality, interwoking, and ease of configuration.
Hello Paolo,
I know that the best solution is implement codec G711.
But customer wants G729r8, if you read from the begining i mention that the issue is only with certain incoming calls .e.g Uruguay,Panama.
Regards.
Re: Strange issue with incoming call from certain countrys
Sorry, but considering how quick you've been in low rating my correct posting, made to help, I will refrain from participate again.
315
