Strange issue with Voice Gateway
Currently I have a Voice Gateway on one of my sites that connects to a PABX via E1 connection. The Voice Gateway is then connected to the WAN with connects it to other remote sites.
The Voice Gateway has VOIP dial-peers configured that were meant to forward voice traffic to other remote sites. However, it seems that when we try to dial those numbers, it is coming up with a 'congestion' message on the phone. Also when you do a show call active voice brief, the following is the result ..
39F3 : 27409 948401910ms.2 +-1 pid:100 Originate 100555 connecting
dur 00:00:00 tx:0/0 rx:0/0
IP 0.0.0.0:0 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 pre-ietf
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
It keeps showing up as g729r8 pre-ietf even though I've not specified that in the configuration. Calls from other remote sites work with the same configuration.
Any ideas?
Re: Strange issue with Voice Gateway
Put the following commands in your local interface of remote voice gateway
interface FastEthernet0/0 --> Local Interface
h323-gateway voip interface
h323-gateway voip bind srcaddr
Also put the following commands on remote voice gateway
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
Is the phone with the message connected to a call manager? Congestion is a message that displays only when CAC has rejected the call.
Have you properly configured locations for your dial plan?
Steve
Please rate all helpful posts.
Issues have been fixed from the previous post. Thanks everyone for your help.
219
