Strange problem with phones
We just deployed some 7965 phones and have had complaints that when users are on a call and then have to imput more numbers (bank info, passcodes etc) the numbers double or triple. So for example they hit 43872 it shows 44444433388888777777772222. We have deployed hundreds of these phones and have never had this issue? We replaced a few phones but the users still experience the issue.
Ideas?
Mike
Hall of Fame Super Red
Re: Strange problem with phones
Hi Mike,
It's likely this "Firmware" related bug (nicely supplied by Nick!)
CSCsv04751 Bug Details
DTMF is not squelched on third gen phones causing duplicate DTMF
Symptom:
Duplicate DTMF is detected and users have problems entering DTMF mid-call. The side tone from the phone appears to be introduced into the RTP stream in addition to the out-of-band signaling normally sent.
Conditions:
This occurs independently of the Call agent, and is seen on both CUCM and CUCME, and is observed on SCCP phone load 8.4.1 SR 1.
Workaround:
Both speaker phone and the headset use a different sidetone than the handset, and they should should not experience the same DTMF problem. Downgrading the firmware is the only other workaround.
Status
Fixed
Severity
2 - severe
Last Modified
In Last Year
Product
Cisco Unified IP Phones 7900 Series
Technology
1st Found-In
8.4(1)
8.5(1)
Fixed-In
8.4(1.21)
8.4(1)ES9
8.4(2.16)
6.1(3.1000.8)
4.1(3)ES150
6.1(3.1000.16)
4.3(2)ES9
4.2(3)ES73
4.1(3)ES151
4.2(3)ES74
4.3(2)ES11
4.1(3)ES153
Hope this helps!
Rob
I'll actually disagree here. The bug I filed that Rob mentioned should have a functional limitation on duplicating it by 1 number.
This is of course, unless you're hitting a 'perfect storm' of duplicate DTMF with multiple bugs/issues.
If you're on 8.4.1 SR1 by all means upgrade your phones and see if you get less duplicate digits.
If your gateways are on 12.4(15)T7 or lower, or 12.4(21) or lower, upgrade those as well to 12.4(15)T9 or 12.4(25).
If you're using MGCP, switch your DTMF method from nte-gw if you're using that to nte-ca.
Otherwise you have a different issue that is a duplicate DTMF problem that creates more than 1 digit. If these don't work, open a TAC case and let me know the SR, and I'll take a look. I've had a particular interest in duplicate DTMF recently.
-nick
Thanks for the information I will check things out and see how it works.
Mike
We are running 8.4.1 SR1 on the phones.
We are running vg224-i6s-mz.124-24.T1.bin on the gateway.
I looked at the config and did not see nte-gw or nte-ca
Here is the config we have
Building configuration...
Current configuration : 3272 bytes
! Last configuration change at 15:25:08 EST Tue Jul 28 2009
! NVRAM config last updated at 15:25:13 EST Tue Jul 28 2009
version 12.4
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
hostname roc_VG224
boot-start-marker
boot system slot0:vg224-i6s-mz.124-24.T1.bin
boot-end-marker
logging message-counter syslog
logging buffered 20000
no logging monitor
no aaa new-model
clock timezone est -5
clock summer-time EST recurring
ip source-route
ip cef
ntp server 10.10.1.1 source FastEthernet0/0
no ipv6 cef
voice-card 0
archive
log config
hidekeys
interface FastEthernet0/0
ip address 10.10.4.226 255.255.255.0
duplex full
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.10.4.1
ip http server
logging trap warnings
logging 63.118.88.137
snmp-server community RW
snmp-server community RO
control-plane
voice-port 2/0
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
ccm-manager redundant-host 10.10.4.10
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.10.4.10
ccm-manager config
mgcp
mgcp call-agent 10.10.4.13 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp behavior g729-variants static-pt
mgcp profile default
dial-peer voice 99922 pots
service mgcpapp
port 2/2
dial-peer voice 99925 pots
service mgcpapp
port 2/5
dial-peer voice 99926 pots
service mgcpapp
port 2/6
dial-peer voice 99929 pots
service mgcpapp
port 2/9
dial-peer voice 999210 pots
service mgcpapp
port 2/10
dial-peer voice 999211 pots
service mgcpapp
port 2/11
dial-peer voice 999214 pots
service mgcpapp
port 2/14
dial-peer voice 999213 pots
service mgcpapp
port 2/13
dial-peer voice 999212 pots
service mgcpapp
port 2/12
dial-peer voice 99920 pots
service mgcpapp
port 2/0
dial-peer voice 99923 pots
service mgcpapp
port 2/3
dial-peer voice 99927 pots
service mgcpapp
port 2/7
line con 0
exec-timeout 0 0
privilege level 15
password
logging synchronous
login
line aux 0
privilege level 15
password
logging synchronous
login
line vty 0 4
privilege level 15
password
logging synchronous
login
transport input telnet
end
Thanks for your help.
Mike
Thanks. I will check it all out.
Mike
Usually happens with 7965 phones
239
