Community Member
Strange transfering problem
Hi Everyone,
I am having a problem with transfered calls, I am sure I have configured correctly for Full-consult transfers but the system is doing blind.
I have been tearing my hair out over this for the last few days and would be very greatful for any help.
Community Member
Re: Strange transfering problem
Just thought I should add I have a 2801 with 16 DSP's, running cme 4.2 on version 12.4(11) XJ4
Hall of Fame Super Red
Hi Scott,
Is this problem with all phones or just the ones not configured with the dual-line command? My guess is that adding the dual-line to all ephones will resolve the problem.
A dual-line ephone-dn has one virtual voice port and two channels to handle two independent calls. This capacity allows call waiting, call transfer, and conference functions within a single ephone-dn. Dual-line mode is supported on all phone types, but is not appropriate for voice-mail numbers, intercoms, or ephone-dns used for message-waiting indicators, paging, loopback, or hunt groups. Overlays of single-line hunt groups onto dual-line buttons are supported.
Ephone-dns are created in single-line mode if the dual-line keyword is not used. Changing an ephone-dn from dual-line mode to single-line mode (and vice versa) requires that you delete the ephone-dn and then recreate it.
Examples
The following example enters ephone-dn configuration mode to create the ephone-dn 5576:
Router(config)# ephone-dn 1
Router(config-ephone-dn)# number 5576
Router(config-ephone-dn)# exit
The following example creates an ephone-dn with the number 1001 in dual-line mode. The no huntstop command allows calls to continue to hunt to other ephone-dns if this one is busy or does not answer. The huntstop channel command disables call hunting to the second channel of this ephone-dn if the first channel is busy or does not answer.
Router(config)# ephone-dn 10 dual-line
Router(config-ephone-dn)# number 1001
Router(config-ephone-dn)# no huntstop
Router(config-ephone-dn)# huntstop channel
From this good CME doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_command_reference_chapter09186a0080611350.html
Hope this helps!
Rob
106
