Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
stream music to ip phone speaker
Is there a way to stream music to your ip phone speaker ?
Re: stream music to ip phone speaker
sorry, not possible. not the 1st time i've heard someone ask for this that some PBXs provide.
java
if this helps, please rate
java
www.cisco.com/go/pdi
I think its possible to stream audio, by using the URI in ip phone service, RTPRX for unicast and RTPMRX for multicast. I tried with unicast and its working allmost perfect. U have to stream the audio with g.711 u law.
Steps
1 - Create one IP Phone service in ur communication manager, with service url,
RTPMRx:239.1.1.1:16390:80
Where 239.1.1.1 matches your multicast ip address. 16390 is the port number of the stream .
And the :80 is optional, and is the volume %.
make sure u r streaming in g.711 ulaw.
Hope this helps.
Has anyone used the Barix
Has anyone used the Barix device as an alternative MOH source?
This definitely is possible
This definitely is possible now. You will need a Barix Instreamer. (converts audio into g.711 uLaw).
Please see their guide on how to integrate:
http://www.barix.com/fileadmin/data/howto/Instreamer-Cisco_application_note_v14.pdf
Hopkins17...thank you...it
Hopkins17...thank you...it worked
1538
