Strip off Connected party digits CUCME
We have a CUCME router connected to a E1 PRI circuit. All outgoing calls must be prefixed with a carrier pre select code of 1320 for cable and wireless to route the calls correctly.
We are experiencing an issue whereby the connected number display on the phone is displaying the prefix for PSTN calls and the customer is complaining that this is not acceptable.
There appears to be a way to stop this behaviour in the full version of CUCM but I cannot find any solution with CUCME.
Can anyone help?
dial-peer voice 5 pots
corlist outgoing call-local
description ** Local Numbers **
destination-pattern 9[1-9]......
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0/0:15
forward-digits 7
prefix 132
Everyone's tags (4)
As you use CME
Then the digits sent to PSTN will appear in your calling IP Phone
Try to use voice translation-profile to add your 132 digits instead of using the prefix command in the dial-peer
it will help as i though
Haitham
The voice translation rule did not resolve the issue.
Any more feedback?
Hall of Fame Super Gold
To my knowledge, connected number display cannot be manipulated.
338
