Hey,
What should the stripe size be for the BE6000 RAID configuration should you have to rebuild the volume? When we got a BE6000 and looked the Stripe size seemed to be set to 64K, but I see documentation saying that 128K is what should be used (although that seems to refer to the RAID 5 configurations).
Anyone know?
Joey
