Stripe Size for BE6000 RAID 10 Configuration.
Hey,
What should the stripe size be for the BE6000 RAID configuration should you have to rebuild the volume? When we got a BE6000 and looked the Stripe size seemed to be set to 64K, but I see documentation saying that 128K is what should be used (although that seems to refer to the RAID 5 configurations).
Anyone know?
Joey
128k is the only thing I was
128k is the only thing I was able to find a reference to.
http://www.cisco.com/c/en/us
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/virtual/CUCM_BK_CF3D71B4_00_cucm_virtual_servers/CUCM_BK_CF3D71B4_00_cucm_virtual_servers_chapter_010.html doesn't make it seem like it only applies to RAID 5.
148
