Stuck calls on 7931 phones with CME/UCE
ccpagel
I have a new install of CME on a C2800 with 12.4(15)T1
The customer is using 20 x 7931 phones. They are experiancing problems on the 7931 where a call with just stop during the conversation (no media) but will remain active on the phone.
If I web browse to the phone it shows no active call, CME (show ephone) also shows no active call.
The only way to clear the problem is to reboot the phone.
We are using local transcoding on the C2800 with a SIP trunk to a service provider - not sure if this is the cause.
Has anyone experianced this issue?
I'm waiting for the smartnet to come through, once it does I'll raise a TAC case.
Chris
paolo bevilacqua
Which FW do you have on the 7931 ?
Also it would be beneficial if you can downgrade to 12.4(11)XJ4 that is a more tested and stable release.
App Load ID jar31sccp.8-2-2ES1.sbn
Boot Load ID tnp31.3-2-0-6.bin
Version SCCP31.8-2-2SR1S
Hardware Revision 3.1
I don't think I can download as the transcoding/SIP config needs the T release IOS.
Chris
Phone FW is latest. You will need help from cisco I'm afraid. If you have not got the smartnet yet, try opening the case with the router S/N. If it is still new /in initial warranty status, they may go ahead and accept the case anyway.
