08-08-2013 02:08 AM - edited 03-16-2019 06:44 PM
I have two 7941's that are stuck in upgrading mode and even after a factory reset they will not do anything else apart from stick in upgrading
how do i fix this ?
thanks
Solved! Go to Solution.
08-08-2013 07:58 AM
Another likely cause is that you're trying to upgrade from a release older than 8.3(3) to a release newer than 8.5(2). If you perform a factory reset on a phone and the default firmware on CUCM is higher than 8.5(2) it will fail with "Auth Fail" on the phone.
You need to upgrade to a release between 8.3(3) and 8.5(2) first, and then upgrade to your final release.
This has been covered many times in this forum
08-08-2013 07:08 AM
Have you done the full factory reset as detailed here?
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a00800941bb.shtml#ipphone
What system are you using to provide the phones with a new firmware after the reset? CUCM? CME? Etc?
Matty
08-08-2013 07:15 AM
Do you have a DHCP configured for the phones and the TFTP server with their FW files for this??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-08-2013 07:38 AM
Check debug of tftp which file it is asking for, If its not in the directory make it available, the one it is asking for.
-W
08-08-2013 07:58 AM
08-12-2013 06:49 AM
thank you
