Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
stuck in upgrading
I have two 7941's that are stuck in upgrading mode and even after a factory reset they will not do anything else apart from stick in upgrading
how do i fix this ?
thanks
1 ACCEPTED SOLUTION
Gold
stuck in upgrading
Another likely cause is that you're trying to upgrade from a release older than 8.3(3) to a release newer than 8.5(2). If you perform a factory reset on a phone and the default firmware on CUCM is higher than 8.5(2) it will fail with "Auth Fail" on the phone.
You need to upgrade to a release between 8.3(3) and 8.5(2) first, and then upgrade to your final release.
This has been covered many times in this forum
Barry Hesk
Intrinsic Network Solutions
Bronze
stuck in upgrading
Have you done the full factory reset as detailed here?
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a00800941bb.shtml#ipphone
What system are you using to provide the phones with a new firmware after the reset? CUCM? CME? Etc?
Matty
stuck in upgrading
Do you have a DHCP configured for the phones and the TFTP server with their FW files for this??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
stuck in upgrading
Check debug of tftp which file it is asking for, If its not in the directory make it available, the one it is asking for.
-W
Gold
stuck in upgrading
Barry Hesk
stuck in upgrading
thank you
180
