Subcribers not sending CDR files to Publisher in the cluster.
HI,
We have call manager cluster 8.6 version and there are 5 nodes in the cluster.
I could see CDR files generated in the subscriber nodes but it is not uploaded publisher node CDR repository .
I am not seeing any CDR files in Publisher preserve folder.
2014-05-06 19:43:41,517 DEBUG [main] cdragent.cdrAgent (cdrAgent.java:213) - After failure to send files in the previous attempt. Creating new ftpClient object
2014-05-06 19:43:41,517 DEBUG [main] sftpapi.ftpClient (ftpClient.java:148) - ftpClient constructor
2014-05-06 19:43:41,517 DEBUG [main] sftpapi.ftpClient (ftpClient.java:150) - host = 166.98.48.155
2014-05-06 19:43:41,517 DEBUG [main] sftpapi.ftpClient (ftpClient.java:151) - user = ccmservice
2014-05-06 19:43:41,517 DEBUG [main] sftpapi.ftpClient (ftpClient.java:153) - localDir = null
2014-05-06 19:43:41,518 DEBUG [main] sftpapi.ftpClient (ftpClient.java:154) - remoteDir = null
2014-05-06 19:43:41,518 DEBUG [main] sftpapi.ftpClient (ftpClient.java:155) - secureFTP = true
2014-05-06 19:43:41,518 DEBUG [main] sftpapi.ftpClient (ftpClient.java:156) - permKey = true
2014-05-06 19:43:41,518 DEBUG [main] sftpapi.ftpClient (ftpClient.java:157) - Component Name : cdragent
2014-05-06 19:43:41,518 DEBUG [main] cdragent.cdrAgent (cdrAgent.java:216) - After creating the ftpClient object
2014-05-06 19:43:41,518 DEBUG [main] sftpapi.ftpClient (ftpClient.java:179) - connect()-->
2014-05-06 19:43:41,518 DEBUG [main] sftpapi.ftpClient (ftpClient.java:182) - connect(): connect for SFTP
2014-05-06 19:43:41,518 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:94) - Inside the SFTPConnection Constructor
2014-05-06 19:43:41,518 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:364) - checkConnection for Publisher using Key Authentication-->
2014-05-06 19:43:41,519 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:365) - checkConnection: UserName : ccmservice
2014-05-06 19:43:41,519 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:366) - checkConnection: hostname : 166.98.48.155
2014-05-06 19:43:41,519 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:215) - getSshClient-->
2014-05-06 19:43:41,519 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:272) - getSshConnector-->
2014-05-06 19:43:41,520 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:227) - SSH Connection object obtained
2014-05-06 19:43:41,566 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:405) - Trying to authenticate using Private Key File : /home/ccmservice/.ssh/id_dsa
2014-05-06 19:43:41,576 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:428) - The User is Authenticated. Need to get the SftpClient
2014-05-06 19:43:41,616 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:432) - SftpClient is obtained Successfully
2014-05-06 19:43:41,617 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:453) - <--checkConnection for Publisher using Key Authentication
2014-05-06 19:43:41,617 DEBUG [main] sftpapi.ftpClient (ftpClient.java:194) - The status of checkConnection : true
2014-05-06 19:43:41,617 DEBUG [main] sftpapi.ftpClient (ftpClient.java:217) - connect():Successfully connect to 166.98.48.155
2014-05-06 19:43:41,617 DEBUG [main] cdragent.cdrAgent (cdrAgent.java:224) - After attempt to get ftpClient connection
2014-05-06 19:43:41,617 DEBUG [main] cdragent.cdrAgent (cdrAgent.java:237) - Sleeping for 60 seconds
2014-05-06 19:44:41,628 INFO  [main] cdragent.cdrAgent (cdrAgent.java:199) - waking up
2014-05-06 19:44:41,628 INFO  [main] cdragent.cdrAgent (cdrAgent.java:384) - handleCDRFiles -->
2014-05-06 19:44:41,663 INFO  [main] cdragent.cdrAgent (cdrAgent.java:285) - At the moment, # of files ready to be transfered to Publisher is 14011
2014-05-06 19:44:41,763 DEBUG [main] cdragent.cdrAgent (cdrAgent.java:426) - sendFile(): Try bldSendFileCmds
2014-05-06 19:44:41,763 DEBUG [main] cdragent.cdrAgent (cdrAgent.java:430) - FtpManager - sendFile() : The Parent directory of the remote directory send the files : /var/log/active/cm/cdr_repository/
2014-05-06 19:44:41,764 DEBUG [main] sftpapi.ftpClient (ftpClient.java:849) - bldSendFileCmds(): -->
2014-05-06 19:44:41,764 DEBUG [main] sftpapi.ftpClient (ftpClient.java:862) - bldSendFileCmds(): - no need to build command file
2014-05-06 19:44:41,764 DEBUG [main] sftpapi.ftpClient (ftpClient.java:863) - local directory: /var/log/active/cm/cdr/
2014-05-06 19:44:41,764 DEBUG [main] sftpapi.ftpClient (ftpClient.java:864) - remote directory: /var/log/active/cm/cdr_repository/trans/
2014-05-06 19:44:41,764 DEBUG [main] sftpapi.ftpClient (ftpClient.java:865) - final remote directory: /var/log/active/cm/cdr_repository/tmp/
2014-05-06 19:44:41,764 DEBUG [main] sftpapi.ftpClient (ftpClient.java:867) - file: cdr_Dublin_03_201404250000_140996
2014-05-06 19:44:41,764 DEBUG [main] sftpapi.ftpClient (ftpClient.java:869) - bldSendFileCmds(): return <--
2014-05-06 19:44:41,764 DEBUG [main] cdrrep.Util (Util.java:102) - checkJVMFreeMemory(): -->
2014-05-06 19:44:41,764 DEBUG [main] cdrrep.Util (Util.java:158) - checkJVMFreeMemory(): <--
2014-05-06 19:44:41,764 INFO  [main] cdragent.cdrAgent (cdrAgent.java:433) - CDRAgent before sending the file: JVM status: [Max = 227.56MB, Total = 58.44MB, Free = 48.29MB (82.64%), Used = 10.15MB (17.36%)]
2014-05-06 19:44:41,765 DEBUG [main] sftpapi.ftpClient (ftpClient.java:499) - sendFiles(): -->
2014-05-06 19:44:41,765 DEBUG [main] sftpapi.ftpClient (ftpClient.java:510) - sendFiles(): file to send = /var/log/active/cm/cdr/cdr_Dublin_03_201404250000_140996
2014-05-06 19:44:41,765 DEBUG [main] sftpapi.ftpClient (ftpClient.java:511) - sendFiles(): remoteDirectory = /var/log/active/cm/cdr_repository/trans/
2014-05-06 19:44:41,765 DEBUG [main] sftpapi.ftpClient (ftpClient.java:518) - sendFiles():remoteDirectoryFinal(NOT NULL)=/var/log/active/cm/cdr_repository/tmp/
2014-05-06 19:44:41,765 DEBUG [main] sftpapi.ftpClient (ftpClient.java:519) - sendFiles():remoteFilePathFinal=/var/log/active/cm/cdr_repository/tmp/cdr_Dublin_03_201404250000_140996
2014-05-06 19:44:41,765 DEBUG [main] sftpapi.ftpClient (ftpClient.java:521) - sendFiles(): localFilePath = /var/log/active/cm/cdr/cdr_Dublin_03_201404250000_140996
2014-05-06 19:44:41,765 DEBUG [main] sftpapi.ftpClient (ftpClient.java:522) - sendFiles(): remoteFilePath = /var/log/active/cm/cdr_repository/trans/cdr_Dublin_03_201404250000_140996
2014-05-06 19:44:41,765 DEBUG [main] sftpapi.ftpClient (ftpClient.java:526) - sendFiles(): uploadFile
2014-05-06 19:44:41,765 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:163) - sendFileThroughSFTP -->
2014-05-06 19:44:41,765 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:174) - Running put command to copy the file
2014-05-06 19:44:41,767 ERROR [main] sftpapi.SFTPConnection (SFTPConnection.java:194) - Sftp Status Exception : com.maverick.sftp.SftpStatusException: Permission denied.: Permission denied
2014-05-06 19:44:41,768 DEBUG [main] sftpapi.ftpClient (ftpClient.java:538) - Sftp Status Exception
2014-05-06 19:44:41,768 ERROR [main] sftpapi.ftpClient (ftpClient.java:539) - SFTP error in transferring file to another machine.
2014-05-06 19:44:41,768 ERROR [main] sftpapi.ftpClient (ftpClient.java:540) - com.maverick.sftp.SftpStatusException: Permission denied.: Permission denied
2014-05-06 19:44:41,768 ERROR [main] sftpapi.ftpClient (ftpClient.java:559) - Exception while sending files: com.maverick.sftp.SftpStatusException: Permission denied.: Permission denied
2014-05-06 19:44:41,768 DEBUG [main] cdrrep.Util (Util.java:102) - checkJVMFreeMemory(): -->
2014-05-06 19:44:41,768 DEBUG [main] cdrrep.Util (Util.java:158) - checkJVMFreeMemory(): <--
2014-05-06 19:44:41,768 INFO  [main] cdragent.cdrAgent (cdrAgent.java:443) - CDRAgent after sending the file: JVM status: [Max = 227.56MB, Total = 58.44MB, Free = 47.77MB (81.74%), Used = 10.67MB (18.26%)]
2014-05-06 19:44:41,768 ERROR [main] cdragent.cdrAgent (cdrAgent.java:509) - sftp failed for file cdr_Dublin_03_201404250000_140996
2014-05-06 19:44:41,768 ERROR [main] cdragent.cdrAgent (cdrAgent.java:519) - Alarm: Unable to successfully send file to repository node.
2014-05-06 19:44:41,768 INFO  [main] cdragent.cdrAgent (cdrAgent.java:548) - raising alarm CDRAgentSendFileFailureContinues
2014-05-06 19:44:41,769 INFO  [main] alarmInf.AlarmSender (AlarmSender.java:107) - alarmName: CDRAgentSendFileFailureContinues
2014-05-06 19:44:41,769 DEBUG [main] alarmInf.AlarmSender (AlarmSender.java:113) - paramName[0] = CDRRepositoryNodeAddress -> paramValue[0] = 166.98.48.155
2014-05-06 19:44:41,769 DEBUG [main] alarmInf.AlarmSender (AlarmSender.java:113) - paramName[1] = CDRAgentNodeAddress -> paramValue[1] = DUB2IPTCCMPIN22/166.98.48.157
2014-05-06 19:44:41,769 DEBUG [main] alarmInf.AlarmSender (AlarmSender.java:119) - sendAlarm ...
2014-05-06 19:44:41,769 INFO  [main] cdragent.cdrAgent (cdrAgent.java:575) - <-- handleCDRFiles
2014-05-06 19:44:41,769 DEBUG [main] sftpapi.ftpClient (ftpClient.java:283) - disconnect(): <-ftpClient->
2014-05-06 19:44:41,769 DEBUG [main] sftpapi.ftpClient (ftpClient.java:287) - disconnect(): SFTP Connection -->
2014-05-06 19:44:41,769 DEBUG [main] sftpapi.SFTPConnection (SFTPConnection.java:492) - disconnect(): SFTP Connection -->
Could you please check with
Could you please check with TAC whether your CUCM version is also affected by the bug CSCsz99841 as I see "ccmservice" user in your logs too? Description Symptom: Cluster Manager will update ccmservice user SSH security keys whenever a new node is added or removed from the cluster Conditions: CDR Agent cannot send CDR files from sub to pub using sftp. This is because SFTP is initiating a connection using the user 'ccmservice' Workaround: i) Stop CDR Agent service on Call Processing Node ii) Gain root access via remote access support account. And then Copy over the authorized keys in the specific user's SSH directory: /home/sftpuser/.ssh/authorized_keys file to /home/ccmservice/.ssh/authorized_keys Root CLI command: cp /home/sftpuser/.ssh/authorized_keys /home/ccmservice/.ssh/authorized_keys iii) Start CDR Agent service on Call Processing Node. Further Problem Description: This was caused by changes that were made to tighten up file permissions around the CUCM file structure
//Suresh Please rate all the useful posts.
Hi suresh, thanks for the
Hi suresh,
thanks for the update..
any other suggestions before reaching cisco TAC
From logs seeing that sftp is
From logs seeing that sftp is initiating a connection with username "ccmservice". This is a known bug caused by incorrect permissions and you will need to open a TAC case as the authorized keys in the specific user's SSH directory need to be copied manually from root access.
CSCsz99841
390
