Subsciber ldap authentications issue
Hi all,
I have two CUCM 9.1 connected correctly and synchronized to ldap server, when i try to login with an ldap user, I got two result:
* with Publisher address I can access to my user web page
* with subscriber address I can't access to my user web page, and I get this error message ''An LDAP error has occurred.Contact your system administrator''
Med
Bronze
Hi MedSince you get an LDAP
Hi Med
Since you get an LDAP error, I would check if the Subscriber is properly connected to the LDAP Server.
cheers
slashdots
VIP Purple
Hi Med, check DBReplication
Hi Med,
check DBReplication by running command utils dbreplication runtimestate.
regds,
aman
Hi, and thank you all for
Hi, and thank you all for your interaction!
I checked the replication and it's correct:
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: Only available on the PUB
DB Version: ccm9_1_1_10000_11
Repltimeout set to: 300s
PROCESS option set to: 1
Cluster Detailed View from CASCCM (3 Servers):
                                PING            CDR Server      REPL.   DBver& R                                             EPL.    REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    (ID) & STATUS   QUEUE   TABLES L                                             OOP?    (RTMT)
CMNCCM  10.9.0.10       5.212   Yes     (2)  Connected   0      match   Yes     (2)
CASCCM  10.9.16.10      0.028   Yes     (4)  Connected   0      match   Yes     (2)
cassrvccmsub    144.145.1.21    3.722   Yes     (3)  Connected   0      match   Yes     (2)
Med
Hi Med,The status of the
Hi Med,
The status of the dbreplication seems ok. Run a utils dbreplication repair all on the publisher. This will fix any mismatches in the tables that could be present. The runtimestate does not indicate mismatches in tables.
Sree
VIP Purple
Hi Med,  what does the user
Hi Med,
what does the user status show in CUCM subscriber ?
regds,
aman
Hi Sree,Yes it was that, now
Hi Sree,
Yes it was that, now I can login with Pub and Sub address.
Thank you all for your precious assistance
Best regards
Med
Hall of Fame Super Silver
There is no seperate LDAP
There is no seperate LDAP integration from subscriber, all configuation including LDAP is done on Publisher. As suggested by Aman check db replication to ensure sub is relicating from pub, also ensure you have LDAP authentication setup as that is seperate from LDAP directory integration.
Chris
923
