Subscriber CCM Service Restart automatically
Hi Support,
We are having one Publisher and 2 Subscribers with version 7.1.2.20000-2. We observerd that, after 10-15 days the CCM service of only one Subscriber restarts automatically . We have collected the Syslog & Alarm logs and we are getting the below error:
Aug 11 13:15:21, KCMCS02, Error, Cisco CallManager, ccm: 7220: Aug 11 07:45:21.211 UTC : %CCM_CALLMANAGER-CALLMANAGER-3-CallManagerFailure: Indicates some failure in the Cisco CallManager system. Host name of hosting node.:KCMCS02 IP address of hosting node.:10.50.1.11 Reason code.:3 Additional Text [Optional]: Cluster ID:KCMCS01-Cluster Node ID:KCMCS02, 5886
Aug 11 13:15:21, KCMCS02, Error, Cisco CallManager, ccm: 7221: Aug 11 07:45:21.212 UTC : %CCM_CALLMANAGER-CALLMANAGER-3-CallManagerFailure: Indicates some failure in the Cisco CallManager system. Host name of hosting node.:KCMCS02 IP address of hosting node.:10.50.1.11 Reason code.:3 Additional Text [Optional]:CCM Intentional Abort: SignalName: PublishRetryAfterTimer, DestPID: PublishEPA[2:100:81:13] Cluster ID:KCMCS01-Cluster Node ID:KCMCS02, 5887
Does anyone faced this problem? Is there any solution for this?
Need help...
Re: Subscriber CCM Service Restart automatically
You have to make sure that you did't get any error during the installation
If this is possible I recommend you to open TAC with Cisco or retry to install it again
Hi Mohamed,
During upgrade of the Subscriber we got one error (attached Screenshot). But we checked the upgradation logs through CLI and it shows successful upgrade.
Hi Vaijanath,
If you didn't get this error during installing the first subscriber then you have to reinstall this subscriber again as I don't like getting any error during installation phase
If you got this error during installation of the first subscriber (which I doubt) and it is working fine then you have to open TAC with Cisco
Wish to hear from you
Hi Mohamed,
I think there is no error(indicated by screenshot)during the installing because the cli logs clearly indicates the successful upgrade. At present I have enabled the traces after this issue. We will chek once the issue reproduces. Need your suggestion...
335
