Subscriber does not see the publisher CCM 4.0(2a) sr1
all, when I try modify a phone, and press update, I get the error:
Error Information
Cannot update data because the publisher is not available. Please try again later. (58)
Details:
Error No. -2147219910 (0x8004063a):
CDBLException Dump: [Cannot update data because the publisher is not available. Please try again later.]
Other than rebooting, how I can re-connect the publisher and subscriber. All services are running on both and both are ping-able.
Thanks for your help.
Green
Re: Subscriber does not see the publisher CCM 4.0(2a) sr1
Check lmhosts, hosts files
If you have DBLhelper try to run it
check CCM versions in both to be the same
Check Event viewer errors
Both servers same subnet?
Use Adminutility to see if passwords are synched
If servers are in production I will open a TAC case to diagnose properly
Hall of Fame Super Red
Hi Rob,
This method should also fix the Call Forward All problem you posted earlier :)
Using DBLHelper to Reestablish a Broken Cisco CallManager Cluster SQL Subscription
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801e7ddf.shtml
Hope this helps!
Rob
476
