Subscriber not available in CUCM Group
I have installed a second server of Call Manager (Subscriber), and in the Cisco Unified Communications Manager Group, this second server is not showed, the installation was performed as follows:
I installed the second server, as a non first node.
The data base was replicated correctly, from the publisher to subscriber.
I upload the license file to node Publisher.
But in the "Cisco Unified Communications Manager group members, I do not see the new server.
I restart the Call Manager service and the Cisco License Manager
Re: Subscriber not available in CUCM Group
Is the CUCM service running in the SUB???
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Ensure that the CM, CTI,
Ensure that the CM, CTI, Database and Admin as well as other Services are activated after installed the Call Manager (Subscriber).
Goto "Tools" > "Service Activation" under Cisco Unified Serviceability.
After services are activated, you should see the Call Manager (Subscriber) on the Cisco Unified Communications Manager Group Members.
Hall of Fame Super Red
Hi Ricardo,
Did you perform Step 4?
Add a New Node to an Existing Cluster
To add a new node to an existing cluster, follow the steps in Table 1.
Table 6     Adding a New Node to an Existing Cluster
Task
For More Information
Step 1
Before you make any changes to your existing cluster, be sure that you have a current backup file.
For more information, refer to the Disaster Recovery System Administration Guide.
Step 2
Perform all pre-installation tasks that apply to your site.
For a list of pre-installation tasks, see Table 1.
Step 3
Ensure that you have the appropriate number of licenses to support adding a new node.
For more information on specifying the required number of licenses, refer to the License Unit Calculator chapter in the Cisco Unified Communications Manager Administration Guide.
Step 4
Before you install the new node, ensure that you have configured it on the first node.
From Cisco Unified Communications Manager Administration on the first node, choose System > Server and configure the IP address for the subsequent nodes. For more information, see the Cisco Unified Communications Manager Administration Guide.
Step 5
Record the configuration settings for each server that you plan to install.
To record your configuration settings, see Table 10.
Step 6
You must install the same software version on all nodes in the cluster. If you do not have the correct version on DVD, you need to either download updated software from Cisco.com or follow the procedure for applying a patch during the installation procedure.
For more information on the different installation options, see the "Installation Overview" section.
Step 7
Follow the procedure to begin installing the software on the DVD to your server.
See "Starting the Installation" section.
Step 8
If you need to upgrade the version of Cisco Unified Communications Manager that you have on DVD, continue with the procedure for applying a software patch.
See the "Applying a Patch" section.
Step 9
Follow the procedure for performing the basic installation.
See "Performing the Basic Installation" section.
Step 10
When the First Node Configuration displays, choose No to configure the new server as a subsequent node.
See Step 10 in the "Performing the Basic Installation" section.
Step 11
Follow the procedure for configuring a subsequent node.
See the "Configuring a Subsequent Node" section.
Step 12
Perform all post-installation tasks that apply to your site.
See Table 13.
Step 13
If your cluster is running in mixed mode, ensure that you have your USB key and the latest security plug-in installed on the PC that you use to communicate with the first node. After you finish installing the new node, you will need to update the CTL file on all nodes.
For more information, see "Applying Security to a New Node in a Secure Cluster" section.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/7_0_1/install/cmins701.html#wp351031
Cheers!
Rob
1853
