Community Member
Subscriber upgrade
Dear Team,
We have cucm cluster of pub and sub 1 & 2. We have upgraded pub and sub 2 from version 9.1 to 11.5  and done with switch version. Sub 1 upgrade still remainng but its showing partition unaligned error as attached snaps. we do not required sub 1.
Please advise, shell i upgrade sub 2  or delete it from the cluster?
VIP Blue
Re: Subscriber upgrade
Hi Waqas,
If you wish to solve partition unaligned issue in sub1, then you can upgrade sub1 and then follow the below procedure. (Take a backup, do a fresh install of sub 1 with the correct OVA and then restore)
https://supportforums.cisco.com/t5/ip-telephony/cucm-8-6-to-cucm-9-1-upgrade-in-place-quot-partitions-unaligned/td-p/2730782
If you no longer need sub 1, then you need to delete it properly. Remove it from system --> Server and that requires cluster reboot starting with the Pub. You need to make sure that the sub is removed properly, else it will cause DB replication issue.
Rajan
Pls rate all helpful posts by clicking the stars below
Highlighted
Community Member
 @Rajan  If i upgrade subscriber 1 TO11.5, Partitions Unaligned error will remain the same ?
there will be any issue with Pub or Sub 2 (already upgraded) ?
Community Member
I am not able to login Sub 1 with OS username and password to upgrade 11.5. Please advise
Silver
You can follow the below procedure to recover the OS admin credentials.
https://supportforums.cisco.com/t5/collaboration-voice-and-video/cucm-operating-system-administrator-password-recovery/ta-p/3107772
And yes in response to your query before this, after the upgrade the partitions might remain unalligned i.e if the upgrade goes through fine. You can always take backup, redeploy 9.1.2 using the right OVA, restore the backup and then go for the upgrade to 11.5.
Procedure for recovery:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/9_1_2/CUCM_BK_C9FFFCD0_00_cucm-release-notes-912/CUCM_BK_C9FFFCD0_00_cucm-release-notes-912_chapter_011.html
Please rate if you find this helpful.
Aeby
Aeby
156
