Suggestions Required
Please I need the solution for the below…….
4 Incoming FXO lines
24 Extensions
7962 Phones
Voicemail, Auto Attendant
Hi Nauman,
Which call server application are you using ? CUCM or CME?
Manish
You can either reach another Cisco Gold Partner for quote based on your needs, or you can also try Cisco presales and ask them what would suit your needs based on those requirements.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
103
