super g3 fax using an ATA 187
                   I can't get this working. I thought at first it was a sip provider issue but switched over to a pri with same result. I can get inbound faxes but cannot get outbound to work. I have tried almost everything I can think os  s3-to-g3, fax rate disable, ecm disable of the dial peers setting the rate to 9600 on the ata all with no success.  thx
166
