Community Member
Supplementary Services over inter cluster trunks
Have a question regarding supplementary services such as hold, transfer and park over inter cluster trunks.
When using Inter Cluster Trunks between two clusters is it possible to place a call on hold or transfer between intercluster phones.
Example phone 1 in cluster A is conversing with phone 1 in cluster B. Phone 1 cluster A transfer phone 1 cluster B to phone 2 in Cluster A.
Would this be possible, do you need to setup QSIG over H323 trunks.
Would it be possible to setup and IP to IP gateway between two gateway where each cluster controls the gateway hence it can perform the transfer operation by suspending the RTP connection on the gateway and directing it to the alternate phone.
Example
Phone 1?M Clust A -H323 GW Clust A -H323GW Clust B -CM Clust B ---Phone 1
Trying to understand how you could use these features between clusters.
Green
Re: Supplementary Services over inter cluster trunks
Hi Billy,
Sure, it will work.
It should work, no need to do so.
It should work also.
I assume you post this because is not working right?
Or you have a proyect coming?
Let us know.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/sys_ad/4_1_3/ccmsys/a02cac.htm#wp1044987
Community Member
I was trying to understand at the detail level how CCM performs the supp services between the trunks. Is it a propriety protocol over the intercluster trunk? I understand how CCM can suspend a gateway it controls in its own cluster and direct voice stream to another phone when transferring.
I could not find reference to documentation on how it would do the transfer between phones in different clusters, without controlling the phones it would need to either send the message between the cluster proprietary as H323 protocol does not provide the supplementary services and my reading indicates CCM does not support H450.
Can you advise the protocol used between the clusters to perform the transfer, hold supplementary services.
Not working on a problem just getting better understanding of the CCM operation.
Bill
176
