03-05-2009 12:09 PM - edited 03-15-2019 04:39 PM
I have been trying to get Cisco Emergency Responder (CER) version 7.0 installed since December 2008. I first made sure my 3rd party IBM X3250 M2 servers I wanted to order were compatible so I verified with TAC prior to order. TAC said they were on the list and ok.
Received CER and servers in December. Tried to load CER, wouldn't load with error about not being able to find driver for hardware. I opened another TAC case and was told they made a mistake and CER wasn't supported on that platform and I would have to order new servers.
Had our Cisco sale rep make sure we ordered the right MCS servers for CER. Waited 2 months to receive MCS servers which were model MCS 7825-I4-IPC1. Servers arrived and were identical to the previous IBM one we purchased other than the Cisco logo on the front.
Tried to load CER on MCS 7825-I4-IPC1, same error as before. Contacted Cisco, oops not supported server Cisco made another mistake and we must RMA the 7825-I4-IPC1's. They say the compatibility documentation is wrong.
Now Cisco is telling me the servers we need are the MCS-7825-I3-IPC1's. The problem is these are an inferior server model compared to the I4's and are now EOS/EOL and won't even be available after June for new orders.
Needless to say I am not happy about this at all and am wondering how Cisco can even sell CER 7.0 if it won't even run on any modern hardware (not even their own).
Has anyone else run into this same issue and what was your solution? Is there any other 7825 server that is not EOS/EOL that will actually run CER 7.0?
03-05-2009 02:09 PM
Hi Jim,
This is really painful for sure! My boss would probably fire me if I purchased EoL boxes, it doesn't make good businees sense. Here are the supported 7825 servers for CER 7.x;
MCS-7825H-3.0-IPC1
HP DL320-G2
3.06 GHz
MCS-7825H-3.0-IPC2
HP DL320-G2
3.06 GHz
MCS 7825I-3.0-IPC1 IBM x306 3.06 GHz
MCS-7825-H1-IPC1
HP DL320-G3
3.4 GHz
MCS-7825-I1-IPC1
IBM x306
3.4 GHz
MCS-7825-H2-IPC1
HP DL320-G4
2.8 GHz
MCS-7825-I2-IPC1
IBM x306m
2.8 GHz
MCS-7825-H2-IPC2
HP DL320-G4
3.4 GHz
MCS-7825-I2-IPC2
IBM x306m
3.4 GHz
MCS-7825-H3-IPC1
HP DL320-G5
2.13 GHz
MCS-7825-I3-IPC1
IBM x3250
2.13 GHz
Release Notes for Cisco Emergency Responder 7.0(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cer/7_0/english/release/notes/cer_70.html#wp42078
If it were me, I would either hold off until a CER Version is released that can be built on the new 7825 models or ask for a "no cost" trade up to the newer model when the two roads between CER and the MCS7825 meet.
Cheers!
Rob
03-05-2009 02:21 PM
Yep, I think every one of those servers listed above are EOL. The info I am now getting is that the non EOL servers will be supported in version 7.0(3) that will be out in the next few months. I'm trying to get a pre-release copy of 7.0(3) Good thought on the no cost trade up too.
