Supporting Multiple Registrars with CME
I am attempting to utilize the "Multiple Registrars on SIP Trunks" IOS feature with my Call Manager Express.
http://www.cisco.com/en/US/docs/ios/voice/sip/configuration/guide/sip_cg-multi-registrars.html
I want to register to a BroadSoft via two different Edge Session Border Controllers.
I have configured the two registrars, but I have a problem when those registration methods go out. Since I am registering to a BroadSoft, I need the registering SIP URI to look like this:
REGISTER sip:test.domain:6034
This works fine when I use a single registration. But when I try to use multiple registrations I get:
REGISTER sip: 11.11.11.11:6034
Which the BroadSoft rejects because the SIP URI does not include “test.domain”
Has anyone else had any experience with multiple registrations with BroadSoft? Thanks in advance.
IOS 15.1(4)M4
sip-ua
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar 1 ipv4:11.11.11.11:6034 expires 3600
registrar 2 ipv4:22.22.22.22:6035 expires 3600
sip-server dns:test.domain
voice service voip
dtmf-interworking rtp-nte
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface Loopback2
bind media source-interface Loopback2
registrar server expires max 120 min 60
asserted-id pai
privacy pstn
localhost dns:ad.lab preferred
no update-callerid
midcall-signaling passthru
privacy-policy passthru
1 ACCEPTED SOLUTION
I think you need to change Registrar IPs into domain name , like this...
Router(config-sip-ua)# registrar 1 dns:test.domain:6034 expires 3600
Router(config-sip-ua)# registrar 2 dns:test.domain:6035 expires 3600
Or you can give a try to SIP profile for modify headers..
https://supportforums.cisco.com/docs/DOC-16174
Manish
Manish
Thanks for the reply.
My problem is that if put the single test domain in the registrar commands, the CME doesn't know where to sent the registration methods.
I will take a look at the SIP profile.
-Tod
The SIP profiles did the trick.  But unfortunately that also means I need a CUBE license with the CME...
306
