07-20-2009 05:01 AM - edited 03-15-2019 07:02 PM
Hello
Usually it's the other way round, but our customer likes to suppress the ringback tone on outgoing calls (outbound dialing for callcenter agents). Is it possible to configure the H.323 (connected to a CUCM) so that the voice path is not cut through before the connect is received?
Any inputs are greatly appreciated.
Stefan
PS: ISDN Q931 Debug of the Alert
162844: Jul 20 14:45:36 CEST: ISDN BR0/0/0 Q931: RX <- ALERTING pd = 8 callref = 0xB3
Progress Ind i = 0x8288 - In-band info or appropriate now available
Solved! Go to Solution.
07-20-2009 11:43 AM
Try this one:
dial-peer voice X pots
progress_ind alert strip 8
It's hidden, and may do what you're looking for.
-nick
07-20-2009 06:43 AM
Try using the "progress_ind {setup | connect | progress} {PI | disable}" dial-peer configuration command.
07-20-2009 07:07 AM
Thanks for the reply
I have already tried the "progress_ind disable" command. Seems like those commands only help if you like to force the ringback tone.
Stefan
07-20-2009 11:43 AM
Try this one:
-nick
07-20-2009 10:22 PM
Hi Nick
Exactly what I was looking for. Many thanks for your help
Have a nice day
Stefan
07-21-2009 01:25 AM
Thanks Stefan
This is the solution that we want.
great work.
Roland
