11-13-2008 08:09 PM - edited 03-15-2019 02:32 PM
Hi all, I have ordered a few of the above named licenses, (SW-CCME-UL-3911), however, I do not believe I have received them. In the boxes that the 3911 phones came in I was given a "Regulatory Compliance and Safety Information for Cisco Unified IP Phones" manual, "Cisco 90-Day Limited Hardware Warranty Terms" document and an "End User License Argeement".
What I was wanting to know is, is the SW-CCME-UL-3911 license supposed to be printed on a separate piece of paper or is it built into the phone?
Thank you all in advance.
11-14-2008 07:07 AM
Hi Will,
In this case the license is "honor based" and is indicated in the PO/Part# you correctly ordered. You will not receive a seperate license so you should be good to go :)
Hope this helps!
Rob
11-16-2008 02:10 PM
Hi Rob, thanks a lot for the information :)
Cheers
Will
