Switch port - configure with or without trunk??
I also posted this question on learningnetwork.cisco.com, but there aren't any good answers on that forum. Hopefully, there will have someone here who can help.
The topology is basic and simple:
Switch - Phone - PC
1. For the first question:
I read in the book & also somewhere on the Internet, and it says for older models of switches, we have to configure trunk mode for the interface:
     # switchport mode trunk
However, for newer switch, we don't need that command, the following are enough:
     # int f0/1
     # switchport mode access
     # spanning-tree portfast
     # switchport access vlan 50
     # switchport voice vlan 10
It means for new models, CDP will detect & configure the trunk automatically????
2. For the 2nd set of questions:
Let say we are using the older models of switches for this question, and the followings are the configuration on the switch (from a lab book):
     # int f0/1
     # switchport trunk encapsulation dot1q
     # switchport trunk native vlan 10     (data VLAN)
     # swichport voice vlan 15
The 1st subquestion is:
I can see that there is no command "# switchport access vlan 10". However, it seems that everything is still working fine. When I asked my friend, he said that we don't need the command "# switchport access vlan 10" because we already configured the command "# switchport trunk native vlan 10". However, I couldn't see any connections between the 2 commands here because that port on the switch is still supposed to be an access port (for the PC). In other words, what I meant is that I will configure like this:
     # int f0/1
And if I want to configure another vlan for the PC instead of vlan 10,  I will do:
     # int f0/1
     # switchport access vlan 20     (data VLAN)  -> now vlan 20 becomes data VLAN
The 2nd subquestion is:
This subquestion is also based on the configuration above:
For the first configuration:
     -> This means the data VLAN is also a native VLAN
For the 2nd configuration:
     -> this means the data VLAN is a normal VLAN
In brief, data VLAN can be either native or non-native VLAN.
Any helps would be appreciated. Thanks a lot
VIP Purple
In general a switchport is an access-port *or* a trunk. If you configure "switchport mode access" (which is also the default), then all "switchport trunk ..." commands have no effect. But they stay in the config and get active the moment you change to a trunk. If you configure "switchport mode trunk" then all "switchport access ..." commands have no effect.
The exception is the situation you describe in your first scenario. There you have a mix of access and trunk. A mix because from configuration-standpoint you configure an access-port. But for the telephone you need dot1q/dot1p-ecapsulated frames and for that you need a trunk. With "switchport voice vlan" you enable the port to behave like a trunk for that one vlan that you specify, but it's not a full featured trunk like with "switchport mode trunk".
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
OK, thanks a lot. But sorry, u didn't directly answer my questions?
VIP Purple
Well, I tried to answer the first question and show that the other questions are not relevant anymore when you realize which config is active if a port is an access-port or a trunk-port.
But you are right that a part on the first question is still missing. CDP doesn't play any role for the switchport. Also a device that doesn't talk CDP could use the auxilary vlan (that's the more or less "official name" of the voice vlan). And I forgot to mention that the command "switchport voice vlan" is only active on an access-port but not on a trunk.
191
