Community Member
switch type primary-qsig....
A customer has a siemens hicom conected to a 3745 router via e1-pri.
the following is the sinaling config:
interface Serial1/0:15
no ip address
encapsulation hdlc
no logging event link-status
no snmp trap link-status
isdn switch-type primary-qsig
isdn timer t321 0
isdn overlap-receiving T302 3000
isdn incoming-voice voice
no cdp enable
my question is: what type of gateway can i use on a cisco unified communication manager 6 that i will integrate to the voice system?... e1-pri ?.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: switch type primary-qsig....
Sure.
Chris
The 3745 is just fine, any ISR router 28/38XX will be optimal depending on number of PRIs required.
Chris
Community Member
ok but my question is...if I can add the 3745 as mgcp gateway with qsig signaling?.
RJB
Sure.
Chris
I assume that you are asking about whether to use a H.323 gateway or an MGCP gateway. In either case, the 3745 will support it, depending, of course, of the IOS feature set you have. And either will work with CUCM 6.X and with the E1-PRI.
1085
