Community Member
$ Symbol Usage
Is it a good practice to end all destination-patterns numbers with the $ symbol?
1 ACCEPTED SOLUTION
Re: $ Symbol Usage
actully dosent matter
as long as u have ur dia-peers spicific u dont need it
but u might found it in some situations like in translation profile u ned to spicify somthing
in distination pattren
1234 will match only 1234
1234$ dose the same
if helpful rate
1 REPLY
Re: $ Symbol Usage
1234$ dose the same
if helpful rate
117
