08-05-2010 07:24 PM - edited 03-16-2019 12:07 AM
Hello Guys,
I really want to simulate a T-1 with 2 x 2600XM routers I have with VWICS in them and a crossover cable. What do I need to do to ge this done
08-05-2010 09:44 PM
If you have another router with T1, cross connects both routers.
Muhammad Amir Raza
08-06-2010 04:55 AM
Do you know where I can find a sample configs for setting these routers up to use ds0-groups and pri-groups? I have never done the configurations before.
08-06-2010 06:07 AM
Sample config FYI.
Router 1
controller e1 0/0/0
linecode hdb3
framing crc4
clock source internal
;Switching Side
pri-group timeslot 1-31
int s0/0/0:15
isdn incoming-voice voice
isdn protocol-emulate network
Router 2
dial-peer voice 1 pots
destination-pattern 9T
forward-digits all
port 0/0/0:15
controller e1 0/0/0
linecode hdb3
framing crc4
clock source line
;User Side
int s0/0/0:15
isdn protocol-emulate user
Muhammad Amir Raza
08-06-2010 05:10 AM
You also need an AIM-VOICE-30 to work with the VWIC cards.
You cannot do anything without it.
The alternative, is the NM voice hardware.
08-06-2010 06:18 AM
I am using a T-1 VWICS. Why do I need a AIM-VOICE-30? All my 24 channels come up when I enter the pri-group command. I already added my 24 PVDM's to both of my HDV module.
08-06-2010 06:22 AM
Because you have NM-HDV. The VWIC would work outside it in presence of AIM-VOICE-30.
08-06-2010 07:09 AM
Now that I have everything to make this work. What would my configuration look like to make this back to back setup work? The post the other guy gave me is for a E-1 setup not T-1. I will not be working with 30 channels and my control channel wil not be s0/0/0:15 but s0/0/0:23.
08-06-2010 07:22 AM
That is pretty much the only difference.
08-09-2010 04:37 AM
I have posted sample E1 configuration for your understanding, I hope you can convert it to T1 configuration.
Muhammad Amir Raza
