Community Member
T.37 Fax via SIP interface
cannot map the fax number when i test the onramp function from router(CUBE). SIP interface to connect to PSTN (via PBX).
-x4630=FAX DID number
-172.16.10.2=PBX IP address connected from router via SIP protocol
-10.0.20.11=Exchange server IP address
Advise please..
Configuration
fax receive called-subscriber $d$
fax send transmitting-subscriber $s$
fax send left-header $s$
fax send center-header $t$
fax send right-header Page: $p$
fax send coverpage enable
fax send coverpage email-controllable
fax interface-type fax-mail
mta send server 10.0.20.11 port 25
mta send subject "FAX receiving via CUBE"
mta send mail-from hostname cube.ucdops1.com
mta send mail-from username fax-user
mta receive aliases cube.ucops1.com
mta receive maximum-recipients 10
mta receive generate permanent-error
application
service app_onramp flash:app_faxmail_onramp.2.0.1.3.tcl
service app_offramp flash:app_faxmail_offramp.2.0.1.1.tcl
dial-peer voice 500 voip
service app_onramp
session protocol sipv2
session target ipv4:172.16.10.2
incoming called-number 4630
dtmf-relay rtp-nte
codec g711ulaw
ip qos dscp cs3 signaling
no vad
dial-peer voice 501 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 4630
information-type fax
session target mailto:fax_in@ucops1.com
mdn
dsn success
dsn failure
dial-peer voice 502 mmoip
service app_offramp
incoming called-number 9T
dsn delayed
dsn success
dsn failure
fax onramp test
cube#10.0.12.10 25
Trying 10.0.12.10, 25 ... Open
220 cube.ucops1.com Cisco NetWorks ESMTP server
mail from:test@test.com
250-2.5.0 No EHLO/HELO was sent! Continuing,
250 2.5.0 Sender <test@test.com> ok
rcpt to:fax=4630@cube.ucops1.com
553 5.1.1 <fax=4630@cube.ucops1.com> no mapping (4630)
554 5.3.0 Internal error prevented operation; closing socket
[Connection to 10.0.12.10 closed by foreign host]
debug fax mta all
*May 4 18:47:56.854: //-1/xxxxxxxxxxxx/SMTPS/esmtp_server_engine_command_rcpt:
CALL_ERROR; faxmail_server_tel_number_translate failed
548
