T.37 Faxing with UC560
I have configured this and appear to be running into a Dial-Peer issue in that I am not matching on the outgoing dial peer. This is a lab configuration and here are the applicable Config entries.
fax receive called-subscriber $d$
fax interface-type fax-mail
mta send server 172.21.12.12 port 25
mta send subject FAX
mta send postmaster myemailaddress
mta send mail-from hostname sendingaddress
mta send mail-from username $s$
application
service onramp flash:/app_faxmail_onramp.2.0.1.3.tcl
service fax_detect flash:app_fax_detect.2.1.2.2.tcl
voice-port 0/1/1
dial-peer voice 233 pots
service onramp
incoming called-number 5551212
direct-inward-dial
port 0/1/1
dial-peer voice 232 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 5551212
information-type fax
session target mailto:myemailaddress
image encoding MH
image resolution fine
dsn failure
I am matching on the incoming - but I thought it should then send it to the next dial peer - but I get no match.
Dec 15 21:53:05.512: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
  Calling Number=, Called Number=, Voice-Interface=0x87D74004,
  Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
  Peer Info Type=DIALPEER_INFO_SPEECH
  Match Rule=DP_MATCH_PORT;
  Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=233
Dec 15 21:53:05.512: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
  dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Dec 15 21:53:05.512: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6475
Dec 15 21:53:05.516: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
  Calling Number=, Called Number=, Peer Info Type=DIALPEER_INFO_SPEECH
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Dec 15 21:53:05.516: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
  dialstring=, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
Dec 15 21:53:05.516: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
  Result=NO_MATCH(-1)
Any help is greatly appeciated.
Heath
Everyone's tags (6)
1 REPLY
Already answered in other post.
Regards.
486
