T.37 no attachment problem
Hi ,
We have cisco 3800 gateway (Version 12.4(24)T3). There is t.37 foip configuration on it. We generally can receive and send fax without problem. But some custermers fax do not come to our smtp server, only ".eml" file is recieved from smtp server. Moreover, gateway send a fax confirmation message to customer despite we cannot receive the fax image.
How can i fix the problem? And how can i stop sending confirmation mail to customer if there is a failure in coming fax.
fax receive called-subscriber $d$
fax send transmitting-subscriber 4101112
fax send center-header $t$
fax send right-header $d$
fax interface-type fax-mail
mta send server 10.xxx.146.23 port 2525
mta send with-subject both
mta send postmaster 04101112@fw.gaxxx.com.tr
mta send mail-from hostname fw.gaxxx.com.tr
mta send mail-from username $s$
mta send return-receipt-to hostname fw.garanti.com.tr
mta send return-receipt-to username $s$
mta send success-fax-only
mta receive aliases subemail.com
mta receive maximum-recipients 100
mta receive generate mdn
dial-peer voice 75 mmoip
service offramp
max-conn 8
information-type fax
incoming called-number 0T
dsn delayed
dsn success
dsn failure
dial-peer voice 37 pots
trunkgroup PRI
service onramp
incoming called-number 4101112
direct-inward-dial
dial-peer voice 74 mmoip
description 80382....
service fax_on_vfc_onramp_app out-bound
max-conn 4
destination-pattern 4101112
session target mailto:$d$@fw.gaxxx.com.tr
mdn
dsn delayed
dsn success
dsn failure
Everyone's tags (3)
203
