Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
T.37 offramp (outgoing, mail2fax) faxes don't work
Hello.
We are trying Cisco scripts app_faxmail_onramp.2.0.1.3.tcl and app_faxmail_offramp.2.0.1.1.tcl for T.37 onramp (incoming, fax2mail) and offramp (outgoing, mail2fax) faxes, respectively.
Incoming faxes work, but outgoing faxes have some problems.
If we send any .tif file to the gateway by mail2fax, the receiving fax machine gives an error; instead, if we try to send the "Cisco_fax.tif" (generated by a previous incoming fax2mail fax), it works correctly.
What's wrong?
How can we generate a "Cisco-compatible" .tif file? Is there a tested image converter to obtain a "valid" file?
Thanks and regards.
1 REPLY
Re: T.37 offramp (outgoing, mail2fax) faxes don't work
Hello.
We have solved all by oneself.
We have found several free softwares, such as (for example) PDFCreator, that can save files in TIFF G3 format.
Regards.
236
