t1 cas caller id mdmf format
Customer ordered a pstn circuit and ended up with a T1 CAS rather than PRI. So naturally the age old how does caller id work.
My understanding is that you need fgd ports to make this work, but I want to be sure of my ground. the carrier is saying they are delivering the number via mdmf format. Isn't that the old delimiter *ani*dnis* kind of thing?  My understanding is that ISR routers don't support this. Is that true?
thx again
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: t1 cas caller id mdmf format
Correct. Sometime CAS circuits require a little timing adjustments.
Contact at the address present in my profile, please.
Ask explicitely... Different people use different terms.
I have a script for *ani*dnis* plus name association. Some custoemr were happy with it until finally switched to PRI.
Do you mean a TCL script?
you are something. do you code the ds0-group and   e&m-wink-start  dtmf dnis?    Or is it done some other way
Bill
okay, out of curiousity what would this script cost?
thanks for all your help. Not sure how you let folks know except to click correct answer. I liked the old way better. If there is a rating system let em know. Thanks again
814
