T1 controller Cannot assign cablelength?
Dear everybody,
I tried to copy other voice gateway config to a brand new Cisco 2821
the original config is
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24
however, when I tried
VG(config-controller)# cablelength long 0db
it returns %invalid input detected at "^" marker
when I type
VG(config-controller)# cablelength long ?
it only returns gain26 and gain36
Is there any criteria to enable the 0db optoin? or do i miss out something?
Sam
Everyone's tags (2)
Hall of Fame Super Silver
That should be the default, what if you issue "sh run all" and look at the configuration?
Chris
controller T1 0/0/0
framing ESF
clock source line
linecode b8zs
Where is "pri-group timeslots 1-24"?
Chris
Silver
What type of VIC are you using? IOS Version?
VIC is VWIC-1MFT-T1= hardware revision 1.0
IOS is c2800NM-ADVENTERPRISEK9-mz.151-4.M4
Silver
Re: T1 controller Cannot assign cablelength?
It looks like the syntax has changed.  Try using "cablelength long gain26 0db".
Edited from gain36 to gain 26 as it looks like gain26 is the default.
so ... the reason could be the IOS version ... does not have the command of >> cablelength long 0db ...
Silver
The syntax just changed for these newer versions of IOS.
539
