09-17-2013 10:08 PM - edited 03-16-2019 07:25 PM
Call flow as below:
phone 8945 -----sip-----> CUCM ----- sip trunk ----> 2900 ----- T1 ---> PSTN
We have a site located in USA which expereience international call to certain country failed.
Calls to Japan is fine but failed to Germany and Brazil. This is really strange.
I have attached debug ccsip, debug voip ccapi inout and debug isdn q931 output on VG for both good call and bad calls.
As i am located in Australia, for test purpose, I have USA DN CFA to desired IDD number.
So call flow as 0280621560 calls 19173388643 (CFA to number starts with 9011).
Called number would be as below:
to Japan: 901181334695211 --- successful
to Germany: 9011491724173015 --- failed, busy signal
to Brazil: 9011551130486173 -- failed, busy signal
Any ideas?
Solved! Go to Solution.
09-18-2013 06:10 PM
Fei,
You can use voice translations on your gateway to do this:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Please remember to rate useful posts, by clicking on the stars below.
09-18-2013 05:00 AM
Hi.
Japan is succesful because you are applying a numbering type "Unknown"
Germany and Brazile are presented as International
Try to change to unknown type calls to Japan and should work.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
09-18-2013 05:25 PM
Hi Carlo
change numbering type to Unknown is something we can do locally or need to be done by carrier?
Fei
09-18-2013 06:10 PM
Fei,
09-18-2013 07:35 PM
Hi Mink
What confuses me the most is there is only one dial-peer for all international outbound calls and there is no numbering plan type define in show run at all. Why Japan's number defined as Unknown type rather than International type?
here is my test translation output, i cant see any difference
m-ifm-usa-ny-vg01#test voice translation-rule 201 +81334695211
Matched with rule 13
Original number: +81334695211 Translated number: 01181334695211
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
m-ifm-usa-ny-vg01#test voice translation-rule 201 +491724173015
Original number: +491724173015 Translated number: 011491724173015
m-ifm-usa-ny-vg01#test voice translation-rule 201 +551130486173
Original number: +551130486173 Translated number: 011551130486173
Rgds
09-19-2013 01:15 AM
Hi Fei
Can you try to increase the T310 timer under serial 0/0/0:23
interface Serial0/0/0:23
isdn T310 60000
Carlo
09-29-2013 10:12 PM
Hi Carlo
sorry abt delay replying.
we had a discuss with carrier, they advised debug calls shows Unknown TON up until the transmitted Setup.
next plan is we are going to modify rule 13 with following command and test out:
rule 13 /^\+/ /011/ type any unknown plan any unknown
i will share the outcomes sooner or later
regards
10-21-2013 10:15 PM
Hi minkdennis
Issue resolved after we modify type and plan on translation rule.
Thx for help.
Fei
