T1/PRI card
I have a call manager express that needs to be interfaced with PSTN network.
I'm looking for a T1/PRI card. Can you help me with a part number for this card and if you have a better recommendation, don't hesitate to list it.
Hall of Fame Super Gold
Re: T1/PRI card
Hi, you either a VWIC-1MFT-T1, or a VWIC2-1MFT-T1/E1.
In both cases, you also need a minimum of 24 DSP resources.
To determine exactly what you need you need to send here "show diag" for the existing router", for calculations to be made.
All this assuming you have an ISR router. If something else, please specify.
Please rate if it helps!
Hall of Fame Super Red
Re: T1/PRI card
Hi Walid,
You would probably want to use a VWIC2-1MFT-T1/E1
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80169812.pdf
Hope this helps!
Rob
591
