T1 PRI Configuration Help!
Hi, I am trying to configure 2x E1/T1 cards in a back-to-back format like this 2801-->T1Crossover-->2811
However, both cards stay in the Layer 1: Deactivated state. I have followed config guides and cant see what I  am missing. My T1 cross over cable is 1-->4, 2-->5, 4-->1, 5-->2.
I have CD and AL lights on both routers, when I unplug the cable, they go to only CD, but the AL appears shortly after. If I reload the 2811, the T1 on the user side (2801) comes up.
2801 - c2801-adventerprisek9-mz.124-25b.bin
2811 - c2800nm-adventerprisek9-mz.124-20.T.bin
2811 Config (Network)
card type t1 0 0
network-clock-participate wic 0
isdn switch-type primary-ni
controller T1 0/0/0
framing esf
clock source internal
linecode b8zs
cablelength short 110
pri-group timeslots 1-24
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
voice-port 0/0/0:23
Cisco2811#sh controll t1
T1 0/0/0 is down.
  Applique type is Channelized T1
  Cablelength is short 110
  Transmitter is sending remote alarm.
  Receiver has loss of frame.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20071011, FPGA: 13, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (5 seconds elapsed):
     40955 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 5 Unavail Secs
  Total Data (last 6 15 minute intervals):
     43348407 Line Code Violations, 638 Path Code Violations,
     3 Slip Secs, 0 Fr Loss Secs, 6 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 6 Severely Err Secs, 5394 Unavail Secs
Cisco2811#sh isdn stat
Global ISDN Switchtype = primary-ni
ISDN Serial0/0/0:23 interface
        ******* Network side configuration *******
        dsl 0, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        NLCB:Calls are Held because of T309= 90.000 seconds
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 1
    Total Allocated ISDN CCBs = 0
T1 0/0/0 is down.
  Data in current interval (154 seconds elapsed):
     1261414 Line Code Violations, 0 Path Code Violations
     2 Slip Secs, 1 Fr Loss Secs, 3 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 3 Severely Err Secs, 151 Unavail Secs
2801 Config (User)
card type t1 0 3
network-clock-participate wic 3
controller T1 0/3/0
framing esf
linecode b8zs
interface Serial0/3/0:23
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/3/0:23
Cisco2801#sh isdn stat
ISDN Serial0/3/0:23 interface
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
    Layer 3 Status:
    Number of L2 Discards = 0, L2 Session ID = 26
Cisco2801#
Cisco2801#sh controll t1
T1 0/3/0 is down.
  Receiver is getting AIS.
  Version info Firmware: 20090408, FPGA: 13, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  Data in current interval (136 seconds elapsed):
     567692 Line Code Violations, 34 Path Code Violations
     9 Slip Secs, 0 Fr Loss Secs, 2 Line Err Secs, 0 Degraded Mins
     6 Errored Secs, 0 Bursty Err Secs, 2 Severely Err Secs, 121 Unavail Secs
Cisco2801#
Hall of Fame Super Gold
Re: T1 PRI Configuration Help!
Likely faulty cable. Moreover, you have not set isdn prototocol network.
Thanks for the quick reply - I've actualy tried 2 different cables, so hopefully its not that.
User my 'network' router I have:
no ip address
encapsulation hdlc
isdn protocol-emulate network
no cdp enable
So that should be there as well. Any other ideas?
Matt
Buggy IOS? Faulty HW?
Also try in E1 mode.
are you sure you need a cross over cable? To test your card, you could create a loop back cable and check for errors.
nevermind, missed the part of connecting two routers together.
Did you ever figure this out?  I am having the same issue, highly annoying.
Chad
What issue ? These are typicaly cabling or configuration issues.
Same here.  We have a local carrier who comes into the building via SIP then offers PRI handoff via some model of Cisco Voice Gateway.  We've connected the customer VG via T1 crossover cable but cannot get Layer 2 to come up - it just bounces between TEI_ASSIGNED and AWAITING_ESTABLISHMENT.  All I see in the Q921 debugs is outgoing messages:
*Jan 17 01:16:36.771: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
*Jan 17 01:16:36.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Jan 17 01:16:37.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Jan 17 01:16:38.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Jan 17 01:16:39.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Jan 17 01:16:40.771: ISDN Se0/1/0:23 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Jan 17 01:16:45.771: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
*Jan 17 01:16:45.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Jan 17 01:16:46.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Jan 17 01:16:47.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Jan 17 01:16:48.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Jan 17 01:16:49.771: ISDN Se0/1/0:23 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Jan 17 01:16:54.771: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
*Jan 17 01:16:54.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Jan 17 01:16:55.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Jan 17 01:16:56.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Jan 17 01:16:57.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Jan 17 01:16:58.771: ISDN Se0/1/0:23 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Jan 17 01:17:03.771: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
*Jan 17 01:17:03.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Jan 17 01:17:04.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Super Bronze
All tx, no rx... if you are happy with your config then speak to the service provider.
If not sure, post up your config, show isdn status and show controller t1/e1 output.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
4350
