Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
T1-PRI QSIG from Cisco 3925 to an Avaya CS 1000 S
I am having trouble getting this connection up.  I have the config and debug below.  I thought it had to do with clocking, but chaning the clocking on the cisco router to internal or line makes no difference.
Thanks for the help.
show run
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24 service mgcp
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
no cdp enable
show controller  t1 0/0/0
T1 0/0/0 is up.
  Applique type is Channelized T1
  Cablelength is long 0db
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info FPGA Rev: 08121917, FPGA Type: PRK4
  Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (23 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     1 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
show idsn status
Global ISDN Switchtype = primary-5ess
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:23 interface
        dsl 0, interface ISDN Switchtype = primary-qsig
         **** Slave side configuration ****
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x807FFFFF
    Number of L2 Discards = 0, L2 Session ID = 47
    Total Allocated ISDN CCBs = 0
debug isdn q921
Sep 10 00:53:05.774: ISDN Se0/0/0:23 Q921: L2_EstablishDataLink: sending SABME
Sep 10 00:53:05.774: ISDN Se0/0/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Sep 10 00:53:06.774: ISDN Se0/0/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Sep 10 00:53:07.774: ISDN Se0/0/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Sep 10 00:53:08.774: ISDN Se0/0/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
debug isdn all:
Sep 10 00:39:58.262: ISDN Se0/0/0:23 MGMNT: CM_MDL_ERR_IND: error G skip idverify 0 switch type 22
Sep 10 00:40:04.270: ISDN Se0/0/0:23 Q931d: srl_send_l3_pak:
source_id = CCM MANAGER 0x0003, dest_id = Q.921 0x0000, prim = DL_EST_REQ 0x0200
priv_len = 4 int_id = 0x2AF6D98 datasize = 16
Sep 10 00:40:04.270: ISDN Se0/0/0:23 Q931d: data =
Sep 10 00:40:04.270:  02AF6D98000000030200044800010000--00000208
Sep 10 00:40:04.270: ISDN  L2_CODE: isdn_l2_process: QUEUE_EVENT state = 0
Sep 10 00:40:04.270: ISDN Se0/0/0:23 PACKET: handle_mail: received:
dest_id = 0, source_id = 3, prim = 200
priv_ln = 4, int_id = 45051288, datasize = 16
Sep 10 00:40:04.270: ISDN Se0/0/0:23 PACKET: L2IF_DispPak: packet - start(3C8107C4), size (16)
Sep 10 00:40:04.270:  AC1CFF84AC1CFF87097B097B003B559D--000006CE
Sep 10 00:40:04.270: ISDN Se0/0/0:23 Q921d: handle_mail: setting pkt to NULL
Sep 10 00:40:04.270: ISDN Se0/0/0:23 BACKHAUL: handle_mail: received (DL_EST_REQ):
priv_ln = 4, int_id = 45051288, datasize = 0
Sep 10 00:40:04.270: ISDN Se0/0/0:23 L2_CODE: L2IF_GetDriverID()
Sep 10 00:40:04.270: ISDN Se0/0/0:23 PACKET: L2IF_SendprimPkt:
source_id (0x20A), state (0x4), dest_id (0x200), event (0x140),
sapi (0x0), ces (0x1),  call_id (0x0),
chan_id (0x0), int_id (0x2AF6D98), free_p (0x1), pkt (0x14176DB8), msecs (0x0), priority (0xA)
Sep 10 00:40:04.270: ISDN Se0/0/0:23 PACKET: L2IF_SendPkt:
chan_id (0x0), int_id (0x2AF6D98), free_pkt (0x1),
pkt (0x105D49C), msecs (0x0), priority (0xA)
Sep 10 00:40:04.270: ISDN Se0/0/0:23 PACKET: L2IF_DispPak: packet - start(3C810678), size (3)
Sep 10 00:40:04.270:  00017F--00000080
Sep 10 00:40:04.270: ISDN Se0/0/0:23 PACKET: L2IF_SendPkt: Sending from L2
dest_id = 3, source_id = 522, prim = 140
  datastart = 3C810668, netstart = 3C810678, datasize = 19
Sep 10 00:40:04.270: ISDN Se0/0/0:23 PACKET: L2IF_DispPak: packet - start(3C810668), size (19)
Sep 10 00:40:04.270:  02AF6D980003020A0140043000010B0000017F--000002C6
Sep 10 00:40:04.270: ISDN  L2_CODE: isdn_l2_process: TIMER_EVENT
Sep 10 00:40:04.270: ISDN  Q921d: isdn_l2d_srq_process: QUEUE_EVENT
Sep 10 00:40:04.270: ISDN Se0/0/0:23 PACKET: handle_l2d_srq_mail: received:
dest_id = 0x0003, source_id = 0x020A, prim = 0x0140
priv_ln = 4, int_id = 0x02AF6D98, datasize = 3
line_status[0] = IF_ACTIVE
Sep 10 00:40:04.270: ISDN Se0/0/0:23 Q921r: User TX ->
Sep 10 00:40:04.274: ISDN  Q921d: isdn_l2d_srq_process: event_count 1
Sep 10 00:40:04.274: ISDN  L2_CODE: isdn_l2_process: state (0x0), event_count (1)
Sep 10 00:40:05.270: ISDN  L2_CODE: isdn_l2_process: TIMER_EVENT
Sep 10 00:40:05.270: ISDN  L2_CODE: l2_timer()
Sep 10 00:40:05.270: ISDN  Q921d: l2_timer: timer (0x2B146D8), timer_type (0x1240)
Sep 10 00:40:05.270: ISDN Se0/0/0:23 L2_CODE: L2IF_GetDriverID()
Sep 10 00:40:05.270: ISDN Se0/0/0:23 PACKET: L2IF_SendprimPkt:
source_id (0x20A), state (0x5), dest_id (0x200), event (0x140),
Sep 10 00:40:05.270: ISDN Se0/0/0:23 PACKET: L2IF_SendPkt:
pkt (0x1244B0B8), msecs (0x0), priority (0xA)
Sep 10 00:40:05.270: ISDN Se0/0/0:23 PACKET: L2IF_DispPak: packet - start(3C810038), size (3)
Sep 10 00:40:05.270:  00017F--00000080
Sep 10 00:40:05.270: ISDN Se0/0/0:23 PACKET: L2IF_SendPkt: Sending from L2
  datastart = 3C810028, netstart = 3C810038, datasize = 19
Sep 10 00:40:05.270: ISDN Se0/0/0:23 PACKET: L2IF_DispPak: packet - start(3C810028), size (19)
Sep 10 00:40:05.270:  02AF6D980003020A0140043000010B9800017F--0000035E
Sep 10 00:40:05.270: ISDN  Q921d: isdn_l2d_srq_process: QUEUE_EVENT
Sep 10 00:40:05.270: ISDN Se0/0/0:23 PACKET: handle_l2d_srq_mail: received:
Sep 10 00:40:05.270: ISDN Se0/0/0:23 Q921r: User TX ->
Sep 10 00:40:05.270: ISDN  Q921d: isdn_l2d_srq_process: event_count 1
Sep 10 00:40:05.270: ISDN  L2_CODE: isdn_l2_process: state (0x0), event_count (1)
Sep 10 00:40:06.270: ISDN  L2_CODE: isdn_l2_process: TIMER_EVENT
Sep 10 00:40:06.270: ISDN  L2_CODE: l2_timer()
Sep 10 00:40:06.270: ISDN  Q921d: l2_timer: timer (0x2B146D8), timer_type (0x1240)
Sep 10 00:40:06.270: ISDN Se0/0/0:23 Q921d: S5_T200_EXPIRY: dlcb->N200=3 dlcb->RC=1
Sep 10 00:40:06.270: ISDN Se0/0/0:23 L2_CODE: L2IF_GetDriverID()
Sep 10 00:40:06.270: ISDN Se0/0/0:23 PACKET: L2IF_SendprimPkt:
Sep 10 00:40:06.270: ISDN Se0/0/0:23 PACKET: L2IF_SendPkt:
pkt (0x105DE14), msecs (0x0), priority (0xA)
Sep 10 00:40:06.270: ISDN Se0/0/0:23 PACKET: L2IF_DispPak: packet - start(3C810B78), size (3)
Sep 10 00:40:06.270:  00017F--00000080
Sep 10 00:40:06.270: ISDN Se0/0/0:23 PACKET: L2IF_SendPkt: Sending from L2
  datastart = 3C810B68, netstart = 3C810B78, datasize = 19
Sep 10 00:40:06.270: ISDN Se0/0/0:23 PACKET: L2IF_DispPak: packet - start(3C810B68), size (19)
Sep 10 00:40:06.270:  02AF6D980003020A0140043000010B0000017F--000002C6
Sep 10 00:40:06.270: ISDN  Q921d: isdn_l2d_srq_process: QUEUE_EVENT
Sep 10 00:40:06.270: ISDN Se0/0/0:23 PACKET: handle_l2d_srq_mail: received:
Sep 10 00:40:06.270: ISDN Se0/0/0:23 Q921r: User TX ->
Sep 10 00:40:06.270: ISDN  Q921d: isdn_l2d_srq_process: event_count 1
Sep 10 00:40:06.270: ISDN  L2_CODE: isdn_l2_process: state (0x0), event_count (1)
Sep 10 00:40:07.270: ISDN  L2_CODE: isdn_l2_process: TIMER_EVENT
Sep 10 00:40:07.270: ISDN  L2_CODE: l2_timer()
Sep 10 00:40:07.270: ISDN  Q921d: l2_timer: timer (0x2B146D8), timer_type (0x1240)
Sep 10 00:40:07.270: ISDN Se0/0/0:23 Q921d: S5_T200_EXPIRY: dlcb->N200=3 dlcb->RC=2
Sep 10 00:40:07.270: ISDN Se0/0/0:23 L2_CODE: L2IF_GetDriverID()
Sep 10 00:40:07.270: ISDN Se0/0/0:23 PACKET: L2IF_SendprimPkt:
Sep 10 00:40:07.270: ISDN Se0/0/0:23 PACKET: L2IF_SendPkt:
pkt (0x1244CD20), msecs (0x0), priority (0xA)
Sep 10 00:40:07.270: ISDN Se0/0/0:23 PACKET: L2IF_DispPak: packet - start(3C810F38), size (3)
Sep 10 00:40:07.270:  00017F--00000080
Sep 10 00:40:07.270: ISDN Se0/0/0:23 PACKET: L2IF_SendPkt: Sending from L2
  datastart = 3C810F28, netstart = 3C810F38, datasize = 19
Sep 10 00:40:07.270: ISDN Se0/0/0:23 PACKET: L2IF_DispPak: packet - start(3C810F28), size (19)
Sep 10 00:40:07.270:  02AF6D980003020A0140043000010B0000017F--000002C6
Sep 10 00:40:07.270: ISDN  Q921d: isdn_l2d_srq_process: QUEUE_EVENT
Sep 10 00:40:07.270: ISDN Se0/0/0:23 PACKET: handle_l2d_srq_mail: received:
Sep 10 00:40:07.270: ISDN Se0/0/0:23 Q921r: User TX ->
Sep 10 00:40:07.270: ISDN  Q921d: isdn_l2d_srq_process: event_count 1
Sep 10 00:40:07.270: ISDN  L2_CODE: isdn_l2_process: state (0x0), event_count (1)
Sep 10 00:40:08.270: ISDN  L2_CODE: isdn_l2_process: TIMER_EVENT
Sep 10 00:40:08.270: ISDN  L2_CODE: l2_timer()
Sep 10 00:40:08.270: ISDN  Q921d: l2_timer: timer (0x2B146D8), timer_type (0x1240)
Sep 10 00:40:08.270: ISDN Se0/0/0:23 Q921d: S5_T200_EXPIRY: dlcb->N200=3 dlcb->RC=3
Sep 10 00:40:08.270: ISDN Se0/0/0:23 PACKET: L2IF_SendprimPkt:
source_id (0x20A), state (0x4), dest_id (0x700), event (0x691),
Sep 10 00:40:08.270: ISDN Se0/0/0:23 PACKET: L2IF_SendPkt:
pkt (0x105BCF0), msecs (0x0), priority (0xA)
Sep 10 00:40:08.270: ISDN Se0/0/0:23 PACKET: L2IF_DispPak: packet - start(3C80F9F8), size (1)
Sep 10 00:40:08.270:  47--00000047
Sep 10 00:40:08.270: ISDN Se0/0/0:23 PACKET: L2IF_SendPkt: Sending from L2
dest_id = 1792, source_id = 522, prim = 691
  datastart = 3C80F9E8, netstart = 3C80F9F8, datasize = 17
Sep 10 00:40:08.270: ISDN Se0/0/0:23 PACKET: L2IF_DispPak: packet - start(3C80F9E8), size (17)
Sep 10 00:40:08.270:  02AF6D980700020A0691043000010C9847--00000380
Sep 10 00:40:08.270: ISDN Se0/0/0:23 Q921d: srl_send_l2_pak:
source_id = Q.921 0x0000, dest_id = ME 0x0700, prim = MDL_ERR_IND 0x0691
priv_len = 4 int_id = 0x2AF6D98 datasize = 17
Sep 10 00:40:08.270: ISDN Se0/0/0:23 Q921d: data =
Sep 10 00:40:08.270:  02AF6D98070000000691043000010C9847--00000374
Sep 10 00:40:08.270: ISDN Se0/0/0:23 Q931d: L3IF_rx_L2_pak: received data
source_id (0x20A), state (0x4), dest_id (0x300), event (0x211),
chan_id (0x0), int_id (0x2AF6D98), free_p (0x0), pkt (0x0), msecs (0x0), priority (0xA)
chan_id (0x0), int_id (0x2AF6D98), free_pkt (0x0),
pkt (0x137FD480), msecs (0x0), priority (0xA)
Sep 10 00:40:08.270: ISDN Se0/0/0:23 PACKET: L2IF_DispPak: packet - start(3DB1BBD8), size (0)
Sep 10 00:40:08.270:  --00000000
dest_id = 3, source_id = 522, prim = 211
  datastart = 3DB1BBC8, netstart = 3DB1BBD8, datasize = 16
Sep 10 00:40:08.270: ISDN Se0/0/0:23 PACKET: L2IF_DispPak: packet - start(3DB1BBC8), size (16)
Sep 10 00:40:08.270:  02AF6D980003020A0211043000010C00--00000219
source_id = Q.921 0x0000, dest_id = CCM MANAGER 0x0003, prim = DL_REL_IND 0x0211
Sep 10 00:40:08.270:  02AF6D98000300000211043000010C00--0000020D
Sep 10 00:40:08.270: ISDN  L2_CODE: isdn_l2_process: state (0x0), event_count (1)
Sep 10 00:40:08.270: ISDN Se0/0/0:23 MGMNT: CM_MDL_ERR_IND: error G skip idverify 0 switch type 22
234
