09-23-2008 12:06 PM - edited 03-15-2019 01:29 PM
I am unable to get a call to come inbound from a T1 on a 3825, and rout it outbound via 711 to an IP address. Please see my config.
card type t1 0 2
card type t1 0 3
network-clock-participate wic 2
network-clock-participate wic 3
trunk group 1
translation-profile incoming profile1
translation-profile outgoing profile1
voice translation-rule 1
rule 1 // // type any national plan any isdn
voice translation-profile profile1
translate calling 1
translate called 1
controller T1 0/2/0
framing esf
linecode b8zs
ds0-group 0 timeslots 1-24 type e&m-wink-start dtmf dnis
cas-custom 0
trunk-group 1 timeslots 1-24
description Concerto Tie #1
controller T1 0/2/1
framing esf
linecode b8zs
cas-custom 0
description Concerto Tie #2
controller T1 0/3/0
framing esf
linecode b8zs
cas-custom 0
description Concerto Tie #3
controller T1 0/3/1
framing esf
linecode b8zs
cas-custom 0
description Concerto Tie #4
voice-port 0/2/0:0
voice-port 0/3/0:0
voice-port 0/2/1:0
voice-port 0/3/1:0
dial-peer voice 101 voip
description IC Server #1
preference 1
service session
destination-pattern ....
session protocol sipv2
session target ipv4:10.2.1.13
dtmf-relay rtp-nte
codec g711ulaw
no vad
the call coming in should have a dnis of 3599
If I do a debug voice dialpeer inout and initiate a call I can see the call come in but this is what I see:
Result=NO_MATCH(-1) After All Match Rules Attempt
can someone shove me in the right direction? Thanks.
Solved! Go to Solution.
09-23-2008 01:15 PM
looks like you need an INCOMING dial peer to match. Try this:
dial-peer voice 1 pots
description Default Incoming Dial Peer
incoming called-number .
direct-inward-dial
09-23-2008 01:15 PM
direct-inward-dial
09-24-2008 01:53 PM
This worked. Thanks for the help. If you have time to explain why this worked I'd appreciate it.
09-26-2008 05:51 AM
A great book for you is the Cisco Press - Cisco Voice Gateways and Gatekeepers. I highly recommend it. Basically in the gateway you have to have both an incoming dial-peer and an outgoing dial-peer that match the Protocol, codec, dtmf, patterns, etc that you are using. The incoming dial-peer accepts the call into the gateway, the outbound Dial-peer directs the call to a destination. There is a lot to cover here, but incoming and outgoing do not have to be the same protocol, dtmf, etc, and this is known as a SBC if its IP to IP. If its Pots to IP, its just a simple voice gateway. The one thing to remember (and what I should have started with) is that there is a hidden dial-peer 0 on every voice router that can serve as your incoming dial-peer sometimes, but in the case of T1s/PRI's it won't answer correctly, so its best to create your own and set it up to answer all incoming calls ( . means all matches). Good luck with it and welcome to IP telephony.
09-26-2008 06:25 AM
Exactly what I was looking for. Thanks for the info. All the telephony books I have picked up revolve around call manager. unfortunately we went with a competitor, so not much of it applies. Ill be picking that book up shortly.
Thanks again.
