10-01-2013 06:55 AM - edited 03-16-2019 07:37 PM
hi All,
i have implemented a ciscsolution running a cisco 2921router as the voice gateway to cucm 8.6.
the customer has an existing legacy system in Asterisk EIC. they want us to link these two systems together, however i have never done this before.
i have read general articles of linking the two via a t1 trunk, however, can anyone provide any specific details as to how i shoukd proceed?
so far have the available t1/e1 port on my router to facilitate the trunk, and i know i need to have the ethernet cable terminated with a t1 cross specification.
10-01-2013 07:21 AM
Hi.
Just out of curiosity.... why don't you use SIP between those systems?
Carlo
Please rate all helpful posts
"The more you help the more you learn"
10-01-2013 09:50 AM
i also asked thi question. but i am working with the Asterisk provider, and he indicated that the verion they are running does will not support the SIP.
10-01-2013 10:02 AM
Hi.
Asterisk is a native SIP softswitch whatever version they are running
Carlo
10-01-2013 10:06 AM
oh i see.. well i dont have any experience with the asterisk part, so i kind of took his word for it..
but can the t1 work?
10-01-2013 10:12 AM
Hi.
Yes It could work but it's a little bit tricky
Sip is definitely easier
Carlo
10-01-2013 04:00 PM
That's the largest bull cr@p I've ever heard. Tell the Asterisk provider to prove it. Agree with Carlo, Asterisk is very popular because it supports SIP.
It can work but with difficulty. The Asterisk box would have to talk (SIP) to CUCM. But the main issue would be the phones hanging off and registering with the Asterisk.
What kind of phones are hanging off Asterisk? I presume they are NOT Cisco otherwise you could've just registered these phones directly with CUCM.
