T37 Faxing configuration for 15.X IOS
I have found several documents on T.37 Faxing but none are overly clear and all seem to reference older IOS.  Does anyone have a document or configuration reference for configuring T.37 fax on 29XX/39XX ISR running 15.X code?
  • IP Telephony
3 ACCEPTED SOLUTIONS
Silver
Fax, Modem, and Text Support over IP Configuration Guide, Cisco IOS Release 15M&T
Configuring T.37 Store-and-Forward Fax
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/fax/configuration/15-mt/vf-t37-str-fwd-fax.html
Posted by WebUser Asad Raza from Cisco Support Community App
The documentation for T37 is the same since many years ago.
the following configuration that worked for me some time ago.
hostname pc1
ip domain name mydomain.com
ip name-server x.x.x.x
voice-card 0
fax interface-type fax-mail
application
service offramp flash:/app_offramp.tcl
service onramp flash:/app_onramp.tcl
!SEND FOR ONRAMP
fax send transmitting-subscriber $s$
fax receive called-subscriber $d$
fax send max-speed 9600
fax send left-header $s$
fax send center-header $t$
fax send right-header Page: $p$
mta send postmaster root@mydomain.com
mta send server x.x.x.x port 25
mta send subject From:
mta send with-subject both
mta send mail-from hostname mail.mydomain.com
mta send mail-from username $s$
mta send return-receipt-to hostname mydomain.com
mta send return-receipt-to username root
!RECEIVE FOR OFFRAMP
mta receive aliases mydomain.com
mta receive aliases pc1.mydomain.com
mta receive aliases mta.mydomain.com
mta receive aliases r1.mydomain.com
mta receive aliases [y.y.y.y]
mta receive maximum-recipients 10
mta receive generate mdn
mta receive generate permanent-error
interface FastEthernet0/1
ip address y.y.y.y 255.255.255.0
no shut
voice-port 0/0/0
connection plar 3683566
caller-id enable
dial-peer voice 651 pots
service onramp
direct-inward-dial
incoming called-number 3683566
forward-digits all
! max-conn 5
port 0/0/0
dial-peer voice 652 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 3683566
information-type fax
session protocol smtp
session target mailto:myemail@mydomain.com
mdn
dsn failure
dsn success
dial-peer voice 653 mmoip
service offramp
incoming called-number .T
mdn
dsn failure
dsn success
dial-peer voice 654 pots
destination-pattern .T
forward-digits all
port 0/0/0
Silver
Thanks all ... these were perfect ...
hostname pc1
voice-card 0
application
!SEND FOR ONRAMP
no shut
voice-port 0/0/0
caller-id enable
service onramp
direct-inward-dial
forward-digits all
! max-conn 5
port 0/0/0
mdn
dsn failure
dsn success
service offramp
mdn
dsn failure
dsn success
forward-digits all
port 0/0/0
382
