T38 rejected by ccm
Hi guys,
We did an upgrade from CUCM version: 7.1.5.34079-1 to CUCM version: 9.1.1.20000-5.
The problem now is that 95% of the incomming faxes are not coming into the fax server. (Some faxes are reveived)
Setup:
pri -> gateway (MGCP) -> CUCM -> ICT -> fax server
In de CUCM logs we see the next:
2 MDCX messages being sent to the gateway. The second one was being ignored.
This was because BOTH MDCX requests were in a=sendrecv mode. However, in the first MDCX, there is NO codec mentioned, while in the second there is.We believe this may be the reason for the MGCPInterface() not doing anything later in the call.
Did someone already had the same issue or knows a solution for the issue that i'm facing?
Any help would be much appreciated.
Laurent
T38 rejected by ccm
First of all, ICT is designed to communicate different CCM clusters, not to a Fax Server. Change the ICT to a H323 Trunk (Gateway):
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/trunks.html#wp1044685
Then you can further troubleshoot.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
T38 rejected by ccm
Jorge,
This is correct.
However, This is a setup for 2007. According to Cisco back in 2007 we had to use the ICT in order for the faxserver to be able to do T.38 with MGCP gateways.
We only had to modify some timers in the call manager:
Media Exchange Interface Capability Timer ---> from 8 to 16
Media Exchange Timer --> from 12 to 20
Laurent
T38 rejected by ccm
Did you capture detailed traces for the failing fax call?
Jorge Armijo
T38 rejected by ccm
Jorge,
Yes I took detailed cm logs of a working fax and a rejected fax flow. Cisco confirmed that this is a bug in the call manager. They are working on a fix now.
T38 rejected by ccm
Hi Laurent,
can I ask you what fax solution you use?
Because in case of our product we use SIP protocol to negotiate the call and maybe it could be helpful in your environment. Moreover, I think it is more user-friendly than ICT.
If so, just follow the link: http://www.2ring.com/netfax
Martin
402
